N Noname_1 Commendable Feb 5, 2017 17 0 1,510 Oct 4, 2018 #1 i use new monitor benq xl2546 240hz ..why cant detect 240hz? only 144hz detect.. i use DVI now
Solution feelinfroggy777 Oct 4, 2018 You need to use Display Port or HDMI 2.0. You will have problems using DVI.
feelinfroggy777 Glorious Dec 13, 2016 5,722 135 45,990 Oct 4, 2018 Solution #2 You need to use Display Port or HDMI 2.0. You will have problems using DVI. Upvote 0 Downvote Solution
N Noname_1 Commendable Feb 5, 2017 17 0 1,510 Oct 4, 2018 #4 but i use the hdmi no detect why? Upvote 0 Downvote
feelinfroggy777 Glorious Dec 13, 2016 5,722 135 45,990 Oct 4, 2018 #5 Something is wrong with your hdmi if it is not detecting it. Upvote 0 Downvote
N Noname_1 Commendable Feb 5, 2017 17 0 1,510 Oct 4, 2018 #6 ok man tqvm...i more question...i use gtx 1070ti it is ok for that monitor ? Upvote 0 Downvote
feelinfroggy777 Glorious Dec 13, 2016 5,722 135 45,990 Oct 5, 2018 #7 Yeah, it is a good GPU. Your CPU may limit hitting the really high fps though at 1080p. Upvote 0 Downvote
N Noname_1 Commendable Feb 5, 2017 17 0 1,510 Oct 5, 2018 #8 i want ask...why before this i use 144hz...in game like pubg got 120-130fps.....but i change to my new monitor 240hz i get 90-100fps ..why ? Upvote 0 Downvote
feelinfroggy777 Glorious Dec 13, 2016 5,722 135 45,990 Oct 5, 2018 #9 I dont know. The monitor should not affect the framerate unless the other monitor was running at lower resolution. Upvote 0 Downvote
N Noname_1 Commendable Feb 5, 2017 17 0 1,510 Oct 6, 2018 #10 my fps low went i use hdmi it same .... Upvote 0 Downvote
Z zachybest Reputable Jan 27, 2018 54 2 4,545 Oct 9, 2018 #11 Use HDMI port. I had the same problem Upvote 0 Downvote
