Hi every body
foxoz
13
Hello,
ihave windows 8 my lpatop is acer aspire E1-531, I am trying to install windows 7 but boot manager wont show me dvd boot !! it show me only network boot what can i do to be able to boot from dvd
Instead of shutting down your laptop as normal, try powering off by holding down the power switch for 5 seconds. Then when you power on look for the boot options at the bottom of the screen to see if more are available.
servis-komputer
change bios to make dvd drive boot first
windows 8
Windows 8 uses an abbreviated Hibernate to achieve fast boot, and the Function keys are not always available when you power on...
@ Servis Komputer - that means it's hard to get into BIOS!
foxoz
13
i changed every thing but still did not appear i enabled every thing but still give me just network boot and another thing which is not dvd or usb
foxoz
13
when i press f12 it comes but what it does not coming to boot from dvd or usb it comes all the time to boot from netwrok and from hardware itself it show me that in
(Boot Manager )
1. windows Boot Manager < Hitachi HTS547575A9E384>
2. Network Boot - IPV4: B8-88-E3-C2-ED-BC
3. -Netowrk Boot-IPV6: B8-88-E3-C2-ED-BC
What do you see in the Boot Page in BIOS? Should look like this:-
You should be able to move the CD/DVD to top of the list
foxoz
13
i swear i did it i made cd/dvd first and usb second but still does not show up some body told me to select an UEFI file as trusted for executing in the security beside boot but i can press it am not allowed to prees it at all icant get it anyway to get it please
foxoz
13
Can't find any reference to UEFI in the manual.
Try opening the Main Page in BIOS and change the SATA Mode to IDE instead of AHCI and see if that makes a difference
foxoz
13
i try it nothing happens also ,, but why i cant acces the select an UEFI file as trusted for executing in the security beside boot maybe if acces it and press it it well works any idea how to acces it !!
Trouble is I don't know what version of Acer he has, it appears some ship with UEFI and others plain old BIOS. The Manual only gives reference to the BIOS pages, so can't see the page where UEFI is enabled/disabled...
Hi :)
He needs to post pics of ALL Bios pages...
All the best Brett :)
Foxoz, can't find any reference to UEFI anywhere but in the BIOS downloads, so unable to advise you any further, unless you can post pictures of your BIOS/UEFI pages to show what you're trying to do...Seems you need to disable UEFI if you have it in order to boot normally. Others trying to install Ubuntu have downloaded earlier BIOS versions, can you post which version you have ? Downloads here
http://support.acer.com/us/en/product/default.aspx?modelId=4097
foxoz
13
ok the UEFI i change it to legacy bios but to disable it cant see where and secure boot i see it but icant acess it any key to press it to acces it !! its turnedoff cant do anything to it
