Hi everyone. Going to build a system unit.
leunyc00
18
Please make any suggestions, reviews or comments with my build. Here's the specs.
i5 7400
Msi h110 pro
Corsair 8gb ddr4 2400MHz
Seagate 500gb
Asus strix gtx 1060 6gb
Omega Curv
Seasonic s12ii 620W.
For things like auto-cad, having more cores is better. The 1060 6gb card is a very good card. In a video card, what you want for CAD work is cuda cores. The 1060 has 1280, the 1070 has 1920. So while the 1060 is a much better value, the 1070 is very much more suitable to your task. What country are you in? Because giving you quotes on prices in the USA does you no good if you're in the UK.
how much r u gonna spend on the build?
it's good tbh but there are better value from AMD with their new Ryzen build...
PCPartPicker part list: https://pcpartpicker.com/list/4H7dsJ
Price breakdown by merchant: https://pcpartpicker.com/list/4H7dsJ/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($193.44 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($56.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory ($105.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($89.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($41.77 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card ($269.49 @ OutletPC)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case ($39.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($58.98 @ Newegg)
Total: $856.63
Generated by PCPartPicker 2017-11-16 05:22 EST-0500
perhaps something like this would be better?
- more cores/threads
- decent stock cooler
- overclockable
Good parts. I don't really like the basic motherboard, but otherwise ok. Is your goal gaming only or mix-use? Gaming only and you're better off with Intel. If it is mixed use, then Ryzen might be a good option.
Finally are you looking for "look at this build" or are you asking strictly for comments on your build? If it is first one, we would need to know your budget. Include budget max and budget goal if they aren't the same.
My budget is exactly 800$ if converted in US currency. And im plannning to use it mainly in gaming and a liite bit of autocad stuff. Im asking for the build itself. If it's worth the price or maybe some adjustments will do that may be better with that build:). And also is the gtx 1060 6b is the one and only gpu that fits with my budget?. Thanks guys:)
yes it's the most balanced one imho
if u can extend to 1k$ u might be able to afford the 1070
u can use the build i mentioned above [u can just ditch the SSD if ur budget is really tight, the total should go down below 800$ after u ditch it :)] if u want the ryzen, or u can go for this one if u prefer intel:
PCPartPicker part list: https://pcpartpicker.com/list/bv2Ynn
Price breakdown by merchant: https://pcpartpicker.com/list/bv2Ynn/by_merchant/
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($199.89 @ B&H)
Motherboard: Gigabyte - Z370 HD3 (rev. 1.0) ATX LGA1151 Motherboard ($101.98 @ Newegg)
Total: $818.09
Generated by PCPartPicker 2017-11-16 05:54 EST-0500
both would do well but if u're looking for high refresh rate monitor too, intel will provide u with more fps, if u're gonna play on 1080p@60/75 hz, the Ryzen is the better choice imo
