They will all perform about the same. Go with whichever you like the most or whichever is cheapest. Personally, I prefer ASUS but I do know the MSI GAMING models are pretty quiet as well.
Which one of these is the best one?
https://www.newegg.com/Product/Productcompare.aspx?CompareItemList=%2D1%7C14%2D137%2D054%5E14%2D137%2D054%2C14%2D126%2D171%5E14%2D126%2D171%2C14%2D500%2D410%5E14%2D500%2D410%2C14%2D137%2D055%5E14%2D137%2D055
the cheapest one
make sure your power supply has the proper pcie cables for whichever one you get, the two more expensive ones require a 6-pin
