[SOLVED] Hi guys, I need some help regarding AIO RGB lighting flickering
Aug 2, 2021
11
Recently i have notice some random flickering on my AIO Lighting. It flicker randomly maybe like twice for 3 minutes but it is bothering me because i have bought it for less than a month. I have tried uninstalled the "RGB Fusion" app and the flicker still occur, even when i am in the BIOS menu.
I am using this model of AIO (ID Cooling Zoomflow 240X ARGB). Wondering is it the AIO lighting defect or something else that causes the problem. If someone knows about it, please let me know. Thank you !
I have shared the video with vimeo, link's below,
Check out the flicker on the top right.
Pc Spec:
SF Leadtex III Superbronz 650 W
Intel I5-11400f LGA1200
Gigabyte B560M DS3H
Gskill 8x16 Trident z 3200Mhz
Palit RTX3070 TI Gaming Pro
Gigabyte 480 Sata SSD
WD 2TB Blue Sata 3.5" HDD
CM MF120 Halo Fan(Single)
Lutfij
Can you check and see what BIOS version you're on at the time of writing? To me it looks like the issue is with your cooler? On that regards, can you show us how you've paired the LED devices in your system? To the motherboard or a standalone controller?
