K Khavstar Reputable Jul 30, 2015 2 0 4,510 Jul 30, 2015 #1 Can i get a gtx 750 ti with this power supply?
D dhaan Reputable Jul 30, 2015 86 0 4,660 Jul 30, 2015 #2 No you cannot it looks like some cheap low quality psu. It also has a 300w max output witch is not enough. Get something with a higher quality and higher wattage. http://pcpartpicker.com/part/corsair-power-supply-cx430 Is an great psu and it is not expensive Upvote 0 Downvote
K Khavstar Reputable Jul 30, 2015 2 0 4,510 Jul 31, 2015 #3 Okay thanks, but would the evga 500 w1 80+ 500w psu do the trick? Upvote 0 Downvote
Diganta Das Distinguished Jul 22, 2013 464 0 19,110 Aug 7, 2015 #4 No get a cooler master 600w.. That will be better.. You can add more components later plus you'll be safe from starting load Upvote 0 Downvote
