It’s one stick of ram and I’ve already tried that methods of going on msconfig and using max memory but still same thing but it says 0 atmUSW WIN+R KEY, TYPE IN MSCONFIG, GO TO BOOT TAB, advanced options, go to maximum memory tab and click on box. Tell me what it shows in there. Do not save anything just yet.
Ok did you try the memory in the other slot? Also what is the memory model number, ADATA XPG 8G WHAT? Like AX----It’s one stick of ram and I’ve already tried that methods of going on msconfig and using max memory but still same thing but it says 0 atm
I haven’t tried putting it in the other slot but I’m sure it will appear the same and the model number is AX4U300038G16A-SB10 hopefully this helpsOk did you try the memory in the other slot? Also what is the memory model number, ADATA XPG 8G WHAT? Like AX----
