Hi im curious if my graphic card is running to hot?
john_poison
9
Hi i have a ASUS Radeon HD 5450 Silent 1GB DDR3 64BIT PCI-E DVI-I HDMI HDCP Passive Low Profile Video Card at its idle is 50-55. When im playing battlefield 2 its running at 80c max is that 2 hot?
That is quite hot for a card of that performance level, but not necessarily surprising considering you have a passive cooler. Even the extreme low end GPUs these days really need a fan. Running your card that hot will likely shorten its lifespan. To extend the life of your card, I would suggest you look for a PCI slot cooler or fan card, and mount that on the slot directly under the 5450. You can find a number of these on newegg, tigerdirect, or any other computer hardware vendor. Hopefully that will get your temps down to more acceptable levels.
Thanks and i cant seem to find a slot cooler fan as u say. This is the site i use to buy my products from http://ncix.com/
Maybe u can find one on there if u have time 😀 But thanks for the info
