Hi I'm still in the process of fine tuning and making sure every part will work as expect.
Marlo_4
Hi I'm wondering if these parts will be Compatible with each other Hopefully If they are I stop changing stuff cause this has been so frustrating to do if you can tell me if they are good to go I'll greatly appreciate it and if not what changes I'll need to make.
https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16827135204&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16811119160&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16822179010&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157364&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16833704241&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151107&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231627&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16819113284&ignorebbr=1
As said, you might want to rethink the whole thing.
I would not put any money into a new AMD FX-8350 system today.
Do NOT get this build you are buying 5 + year old components that struggle today already with gaming. Tell me the budget and I'll make you something far better.
https://pcpartpicker.com/list/PKB8qk
PCPartPicker part list: https://pcpartpicker.com/list/PKB8qk
Price breakdown by merchant: https://pcpartpicker.com/list/PKB8qk/by_merchant/
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor ($185.88 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: Gigabyte - GA-AB350M-Gaming 3 Micro ATX AM4 Motherboard ($88.98 @ Newegg)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-2666 Memory ($69.99 @ Amazon)
Storage: Sandisk - SSD PLUS 480GB 2.5" Solid State Drive ($136.57 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card ($359.99 @ Newegg)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply ($34.89 @ Newegg)
Total: $957.07
Generated by PCPartPicker 2017-05-27 15:01 EDT-0400
Much much better. Just click on the upper right on view by merchant and then you can see newegg. I left the case out as that is for you to decide. Any micro atx motherboard compatible case will do.
EDIT: OOPS forgot to add the ram you can view it in the link.
