[SOLVED] Hi so i just purchased some new ram for my system!! and i checked the compatibitlity aspect but didnt check the my max speed of my motherboard and CPU
Oct 1, 2020
33
so I just purchased some G.SKILL Ripjaws ddr4 3200 2x8 set of ram and I checked the compatibility but not the max frequency how do I check for that and I need some help because I'm now nervous it wont work with my computer. specs:
Ryzen 3 2200g
team group elite + ddr4 8.00 GB ram
X470 Master SLI/as and its by asr rock
RX 580
corsair CX450M
SSD 240 GB hard drive 1 TB
Thermaltake.
tennis2
Judicious
It will work fine.
Whether or not a 2200G will hit 3200MHz RAM.....that's probably the limit of what you can expect. But even if you're running 3000MHz, it wasn't worth buying a slower 3000MHz kit because they were/are likely the same price.
tennis2
Judicious
It will work fine.
