Hi. I have an issue I cannot seem to figure out. I just changed my case and power supply. I moved my build to a new case and cleaned it. Though after putting it all back together I noticed my CPU temps were abnormally high. On boot it was 80c and only went down to 65 while doing nothing. Launching a browser, it would spike to 88 degrees. I tried to launch games and the CPU would hit 91c and then crash after a minute. I double checked everything. Fans working, fresh thermal paste, re mounting the AIO, reset bios so on. I noticed the AIO pump temps were only at 30-40c, and I thought the AIO was broken or something even though the pump was running at max. There was no heat being output from the rad. So, I changed the cooler to a stock AMD Wraith cooler and now I’m hitting 90c when just opening a browser, so I don’t think it’s the AIO or mount that was the problem. Is it something wrong with the PSU/motherboard/power delivery or just the AIO which was working fine before?
On a quick note, when I cleaned the AIO it was attached to the motherboard and I may have lifted the motherboard by just holding the radiator when clean it. Which may have put some strain on the socket / motherboard. Not sure if this is an important factor or not.
What I’m thinking is that there might be something wrong with the CPU or the mounting, but I don’t know what it could be or what caused it. I have bought a new AIO which should come soon, but after switching to the Wraith cooler I'm fearful that it might not help at all. Would really appreciate some help and opinions.
Specs:
AMD Ryzen 5800x
Asus x470-f Gaming
Corsair GTX H100i (240mm aio)
EVGA 3080ti hybrid
Corsair vengeance 32gb 3200mhz
Corsair RM850X V2 (850W)
Specs:
AMD Ryzen 5800x
Asus x470-f Gaming
EVGA 3080ti hybrid
