High cpu temps
Denis Stoikovski
2,200
So i get 45-52 avg 46 core 0 same in core 1 48-53 avg 48 in core 2 49-52 core 3 avg 51 is this normal while running minecraft? the program i use is core temp 1.0 RC6 also what is TDP and tj max?
That temperature is fine. TDP is the power consumption of the CPU and how much heat it will produce (so coolers have rated TDPs), tj max is the max temperature that the CPU can run at as per regulation.
And what about if i get some nice stock cooler? will it go to max 20-30c ?
