[SOLVED] High CPU temps
meckstroth14
26
Under gaming load my CPU gets up to 75 C and my GPU also gets up to 73-75 C
My specs are : i7 4770 @ 3.4 GHz
Evga Gtx 1070
Should I worry about these temps? I probably game 4-8 hours on any given day.
Also my CPU is about 5 years old, GPU about a year and a half old
Those temperatures are to be expected while components are under stress, it wont cause damage but if you desire lower temperature you might consider
1# cleaning your pc
2# upgrading your case to one with better airflow/getting more fans
3# getting special cooler other than stock one
