High CPU usage and RAM usage on idle??? Help
EvooHD
289
21
Hello, yesterday i reinstalled my Windows 7, today i saw something strange on "CPU Meter" My CPU Usage was 25-35-48% and so on. prety Unstable,
i opened TaskManager, and saw that my 4Core is being used so much.
I have
i5-4690K 3.5 STOCK clock
MSI Z97 GAMING 3
my 4core is used till 60-70-45 and so on, when others not so much...
Also my USED RAM: 5400MB (its 5GB on idle)?? free memory 2,7GB
is something running in background that using my Memory so much and that why my CPU usage is prety unstable??
When i opened Resource Monitor i saw this little thing called
svchost.exe (netsvcs) and its using CPU: 25 Avarage CPU: 24.88
also for memory
svchost.exe using 1 566 848(KB)
What can be problem???
This is fresh windows 7, (Just installed Drivers from MotherBoard disc, GPU Drivers from nVidia, and some other light stuff, i dont have right now even Antivirus program.
EDIT: There is IMAGE - http://imgur.com/1H9wqaO
Thanks-Evoo
Rabmac
1,325
244
Sounds like Windows update.
If you open task manager (ctrl+alt+del) and got performance tab. Here you will see SVChost (process) and wuaserv (service) using large amounts of processes.
EvooHD
289
21
http://imgur.com/DocDxPV
Here are image of Performance Tab
i dont see (wuaserv, service)
only svchost
Can i turn off Windows Update service? so the svchost is turned off, and not using my CPU and RAM , like 5GB on idle thats almost all my ram...
GTA5 even uses 5-6GB... like hello Microsoft?
Rabmac
1,325
244
If you open the CPU tab you should see it listed there.
You can turn Windows update off while you are using the PC but I wouldn't advise that you ignore updating Windows.
As you have just installed Windows the updates are going to take 1-3 days to fully update. I suggest leaving it running overnight and just leaving it until it finishes.
EvooHD
289
21
Yes it is, and its using 24 CPU.. others using 0-1 ... How can i get rid of this?
Rabmac
1,325
244
You right click it and select end process.
However, if you don't update Windows your PC is at greater risk of being infected, so I strongly advise that you update it.
EvooHD
289
21
Thank for help.
But do you think updating Windows 7, with Microsoft , will make it better? Everyone knows Microsoft windows updates when u install them and your computer is like Brick, Running slow.
But i will try install them now.
Do i need to go services. ? and Click Windows Updates " Manual " Disabled??
so next time when boot up pc all my WindowsUpdates is disabled can i do this?
<watch the language>
Rabmac
1,325
244
My advise is don't install the recommended updates but definitiley install the important updates because they make your PC more secure.
I would not set Windows update to manual in the services tab. Best to open Windows updates and change settings there.
EvooHD
289
21
Alright i will do it.! Thank you for your time ,and help.! :)
Similar threads
