[SOLVED] High DPC Latency with electric popping noise win 10
sagizzz
13
Hello, I'm already exhausted from these annoying noises.
Owe the help of the experts to fix the problem that is freaking me out.
Attaches the information through the latencymon software.
_
CONCLUSION
_
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to
a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:23:32 (h🇲🇲ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: System Product Name, System manufacturer
CPU: AuthenticAMD AMD Ryzen 9 5900X 12-Core Processor
Logical processors: 24
Processor groups: 1
RAM: 32682 MB total
_
CPU SPEED
_
Reported CPU speed: 370 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
_
MEASURED INTERRUPT TO USER PROCESS LATENCIES
_
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes
the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 305.0
Average measured interrupt to process latency (µs): 4.507788
Highest measured interrupt to DPC latency (µs): 301.90
Average measured interrupt to DPC latency (µs): 1.033574
_
REPORTED ISRs
_
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 13.760
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.000322
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.000345
ISR count (execution time <250 µs): 274900
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 3181.170
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 466.77 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.005323
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0.009235
DPC count (execution time <250 µs): 857707
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 4
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 1
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires
reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see
which programs were hit.
Process with highest pagefault count: nvcontainer.exe
Total number of hard pagefaults 7397
Hard pagefault count of hardest hit process: 3265
Number of processes hit: 35
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 2.923150
CPU 0 ISR highest execution time (µs): 2.770
CPU 0 ISR total execution time (s): 0.001395
CPU 0 ISR count: 2452
CPU 0 DPC highest execution time (µs): 191.890
CPU 0 DPC total execution time (s): 0.207122
CPU 0 DPC count: 44607
_
CPU 1 Interrupt cycle time (s): 1.466964
CPU 1 ISR highest execution time (µs): 1.370
CPU 1 ISR total execution time (s): 0.000251
CPU 1 ISR count: 562
CPU 1 DPC highest execution time (µs): 142.380
CPU 1 DPC total execution time (s): 0.007560
CPU 1 DPC count: 3059
_
CPU 2 Interrupt cycle time (s): 4.491164
CPU 2 ISR highest execution time (µs): 13.760
CPU 2 ISR total execution time (s): 0.021986
CPU 2 ISR count: 54318
CPU 2 DPC highest execution time (µs): 184.370
CPU 2 DPC total execution time (s): 0.571105
CPU 2 DPC count: 169248
_
CPU 3 Interrupt cycle time (s): 7.608627
CPU 3 ISR highest execution time (µs): 12.180
CPU 3 ISR total execution time (s): 0.069539
CPU 3 ISR count: 179924
CPU 3 DPC highest execution time (µs): 176.960
CPU 3 DPC total execution time (s): 1.409442
CPU 3 DPC count: 315250
_
CPU 4 Interrupt cycle time (s): 1.713432
CPU 4 ISR highest execution time (µs): 1.330
CPU 4 ISR total execution time (s): 0.000186
CPU 4 ISR count: 253
CPU 4 DPC highest execution time (µs): 95.470
CPU 4 DPC total execution time (s): 0.010944
CPU 4 DPC count: 2263
_
CPU 5 Interrupt cycle time (s): 1.960597
CPU 5 ISR highest execution time (µs): 2.160
CPU 5 ISR total execution time (s): 0.000546
CPU 5 ISR count: 1518
CPU 5 DPC highest execution time (µs): 188.440
CPU 5 DPC total execution time (s): 0.018415
CPU 5 DPC count: 7836
_
CPU 6 Interrupt cycle time (s): 1.686008
CPU 6 ISR highest execution time (µs): 1.280
CPU 6 ISR total execution time (s): 0.000420
CPU 6 ISR count: 990
CPU 6 DPC highest execution time (µs): 117.690
CPU 6 DPC total execution time (s): 0.022289
CPU 6 DPC count: 3426
_
CPU 7 Interrupt cycle time (s): 2.297626
CPU 7 ISR highest execution time (µs): 4.250
CPU 7 ISR total execution time (s): 0.002705
CPU 7 ISR count: 7998
CPU 7 DPC highest execution time (µs): 96.310
CPU 7 DPC total execution time (s): 0.049202
CPU 7 DPC count: 13553
_
CPU 8 Interrupt cycle time (s): 2.101840
CPU 8 ISR highest execution time (µs): 3.360
CPU 8 ISR total execution time (s): 0.004828
CPU 8 ISR count: 11956
CPU 8 DPC highest execution time (µs): 155.290
CPU 8 DPC total execution time (s): 0.124545
CPU 8 DPC count: 23923
_
CPU 9 Interrupt cycle time (s): 1.413445
CPU 9 ISR highest execution time (µs): 3.060
CPU 9 ISR total execution time (s): 0.000944
CPU 9 ISR count: 1934
CPU 9 DPC highest execution time (µs): 295.290
CPU 9 DPC total execution time (s): 0.041094
CPU 9 DPC count: 10153
_
CPU 10 Interrupt cycle time (s): 1.510021
CPU 10 ISR highest execution time (µs): 2.530
CPU 10 ISR total execution time (s): 0.000296
CPU 10 ISR count: 602
CPU 10 DPC highest execution time (µs): 89.850
CPU 10 DPC total execution time (s): 0.007687
CPU 10 DPC count: 1252
_
CPU 11 Interrupt cycle time (s): 1.322225
CPU 11 ISR highest execution time (µs): 1.320
CPU 11 ISR total execution time (s): 0.000175
CPU 11 ISR count: 423
CPU 11 DPC highest execution time (µs): 23.060
CPU 11 DPC total execution time (s): 0.003917
CPU 11 DPC count: 831
_
CPU 12 Interrupt cycle time (s): 3.810092
CPU 12 ISR highest execution time (µs): 12.190
CPU 12 ISR total execution time (s): 0.002553
CPU 12 ISR count: 1604
CPU 12 DPC highest execution time (µs): 185.810
CPU 12 DPC total execution time (s): 0.191821
CPU 12 DPC count: 96248
_
CPU 13 Interrupt cycle time (s): 3.911864
CPU 13 ISR highest execution time (µs): 10.790
CPU 13 ISR total execution time (s): 0.002501
CPU 13 ISR count: 1246
CPU 13 DPC highest execution time (µs): 135.090
CPU 13 DPC total execution time (s): 0.185576
CPU 13 DPC count: 121525
_
CPU 14 Interrupt cycle time (s): 2.029543
CPU 14 ISR highest execution time (µs): 12.160
CPU 14 ISR total execution time (s): 0.002953
CPU 14 ISR count: 2673
CPU 14 DPC highest execution time (µs): 110.270
CPU 14 DPC total execution time (s): 0.032212
CPU 14 DPC count: 9346
_
CPU 15 Interrupt cycle time (s): 1.977588
CPU 15 ISR highest execution time (µs): 12.090
CPU 15 ISR total execution time (s): 0.004781
CPU 15 ISR count: 5071
CPU 15 DPC highest execution time (µs): 110.150
CPU 15 DPC total execution time (s): 0.044133
CPU 15 DPC count: 9139
_
CPU 16 Interrupt cycle time (s): 1.737404
CPU 16 ISR highest execution time (µs): 1.430
CPU 16 ISR total execution time (s): 0.000126
CPU 16 ISR count: 207
CPU 16 DPC highest execution time (µs): 112.340
CPU 16 DPC total execution time (s): 0.005916
CPU 16 DPC count: 1574
_
CPU 17 Interrupt cycle time (s): 1.274804
CPU 17 ISR highest execution time (µs): 1.670
CPU 17 ISR total execution time (s): 0.000029
CPU 17 ISR count: 45
CPU 17 DPC highest execution time (µs): 47.010
CPU 17 DPC total execution time (s): 0.000797
CPU 17 DPC count: 440
_
CPU 18 Interrupt cycle time (s): 1.231946
CPU 18 ISR highest execution time (µs): 1.040
CPU 18 ISR total execution time (s): 0.000008
CPU 18 ISR count: 9
CPU 18 DPC highest execution time (µs): 20.380
CPU 18 DPC total execution time (s): 0.001135
CPU 18 DPC count: 571
_
CPU 19 Interrupt cycle time (s): 1.106898
CPU 19 ISR highest execution time (µs): 1.160
CPU 19 ISR total execution time (s): 0.000015
CPU 19 ISR count: 20
CPU 19 DPC highest execution time (µs): 18.030
CPU 19 DPC total execution time (s): 0.000573
CPU 19 DPC count: 324
_
CPU 20 Interrupt cycle time (s): 4.978038
CPU 20 ISR highest execution time (µs): 1.810
CPU 20 ISR total execution time (s): 0.000434
CPU 20 ISR count: 728
CPU 20 DPC highest execution time (µs): 1201.830
CPU 20 DPC total execution time (s): 0.117587
CPU 20 DPC count: 12352
_
CPU 21 Interrupt cycle time (s): 1.733466
CPU 21 ISR highest execution time (µs): 0.890
CPU 21 ISR total execution time (s): 0.000019
CPU 21 ISR count: 30
CPU 21 DPC highest execution time (µs): 77.680
CPU 21 DPC total execution time (s): 0.006294
CPU 21 DPC count: 1455
_
CPU 22 Interrupt cycle time (s): 2.858935
CPU 22 ISR highest execution time (µs): 1.050
CPU 22 ISR total execution time (s): 0.000128
CPU 22 ISR count: 200
CPU 22 DPC highest execution time (µs): 130.920
CPU 22 DPC total execution time (s): 0.029582
CPU 22 DPC count: 3325
_
CPU 23 Interrupt cycle time (s): 3.005756
CPU 23 ISR highest execution time (µs): 1.480
CPU 23 ISR total execution time (s): 0.000081
CPU 23 ISR count: 137
CPU 23 DPC highest execution time (µs): 3181.170
CPU 23 DPC total execution time (s): 0.041408
CPU 23 DPC count: 6013
which in put ? Front headphone jack or Motherboard ?
Back to the motherboard usb 3.0
I tried to use speakers with aux but it was still the same problem the this cracking popping noise.
I have other computer with other motherboard but the same graphics card and the problem is the same.
I searched on Google and all said that this problem is something with drivers.
I really don't know what to do
trying plugging a normal set of head phones in the green port
I tried it.. Of course.
I know that is a something that relates to drivers.
This is something that was also on my previous computer. The problem is that I do not know which driver to delete and what to install because everything is new and the computer is new as well.
