High end laptop running minecraft at low fps
John_594
Commendable
Jan 7, 2017
I recently bought a new laptop, it can run games like GTA V and Dying Light to at least 30fps. But when i play minecraft, modded or otherwise, i'm lucky to get 4 fps. What do?
It depends on many things, what are the specs on your computer. What are you Minecraft settings. A couple of things it could be. Sometimes AMD cards go berserk with the Minecraft mipmapping, turn that off, it shouldn't matter for NVidia cards from what I know.....
It could also be that your settings are still just to high.
It might also be that Java is running entirely off the CPU, this happens because the computer doesn't recognise Minecraft as a game, and Java is usually used for small tasks. If you are using a NVidia GPU, try going to the control panel -> Manage 3D Settings -> Program Settings -> Add, then select Java... if you have recently closed MC it will be there, otherwise, just search for it..... Once you add it click apply...
It might also be that Java is running entirely off the CPU, this happens because the computer doesn't recognise Minecraft as a game, and Java is usually used for small tasks. If you are using a NVidia GPU, try going to the control panel -> Manage 3D Settings -> Program Settings -> Add, then select Java... if you have recently closed MC it will be there, otherwise, just search for it..... Once you add it click apply down the bottom right and you are done! Hopefully this helps, but please also post your specs
Hi, sorry im late but i believe i have your answer.
Go into nvidia control panel >manage 3d settings > program settings > add > look for minecraft's java > use second dropdown to select the proccessor.
Hope this helps.
My answer already said this, if you read it
yeah im blind my bad
