[SOLVED] High-end system Warzone low FPS
Sep 10, 2021
Hi guys
Asus Crosshair VIII Hero Ryzen 9 5900X @ 4.5 ghz 1.26v - Corsair H150i pro cpu temp 60 - 66 celcius
Asus Rog Strix 3080 OC
G Skill 16GB CL19 4266 mhz 1.4V (I triedCL16 4000 but same fps) F4-4266C19D-16GTZR
Corsair MP600 500gb m2 ssd
Corsair HX1000i 1000w psu
Thermaltake Core v51 case
Asus PG258Q 1080p 240hz
Windows 10 21H1 (LEGIT) up to date
FPS 100-140
there is my settings
https://ibb.co/3kK3yfD
https://ibb.co/K7nCDpG
https://ibb.co/rHkszpV
https://ibb.co/pv0zhDn
https://ibb.co/Tm7R05v
https://ibb.co/4PGrbXs
Hi guys
FPS 100-140
Try these...
Hi guys
FPS 100-140
Try these:
  • Disconnect from internet
  • Uninstall gpu driver using DDU (clean and do not restart).
  • Uninstall all the processors on device manager (should be 24 on yours) like this:
  • Restart the pc to bios, and update to the latest bios(download, extract the files and copy it to flashdrive, plug it on top rear usb slot then reboot to bios and flash the bios).
  • boot up to windows and install the latest AMD Chipset driver, reboot and connect to internet.
  • Install the latest nvidia driver.
  • And check windows update (and optional updates) if there is any. Also enable Hardware Accelerated Graphics Scheduling in graphics settings like this and reboot:
*do this all offline until reboot after installing amd chipset driver, also you may reboot to bios after all of this to set the XMP (and do your settings you had previously), make sure your ram is on slot 2 and 4. Download needed files (highlighted word) before doing step 1, do the step by orders.
Make sure the psu connected to the gpu is 1 pcie cable per 1 slot (use main cable, not the branches/split):
Try these:
Thx a lot bro i will try this at to night
my bios version lastest and my rams 2 - 4 slots right
Reactions: Koekieezz
