Currently i am running a gtx 1070 ti in a pretty open case with 6 fans and relatively positive air pressure. My issue is that my idle temps tend to hover around 36 to 40c with a relatively aggresive fan curve. Temps in my house are at 70f on average or colder. Its not a reference card but it does have a pretty [strike]xxxx[/strike] cooler from pny. Ive replaced the thermal paste in the hopes that this would help. Its unfortunate that the thermals are so garbage because i can push a decent overclock when i put the pc outside. I know its the card itself, due to testing and running 2 970s in sli with better temps and a 1060 6bg that all run roughly 10c cooler on average. Really I'm just trying to figure out if i should attempt to rma the card, or find a way to put a different heat sink and cooler on the gpu. I also noticed when i took the heatsink off the second time, the thermal paste was much thinner in the center of the chip compared to the outside. Btw the pny card does not have a blower style cooler but it does use a reference pcb. Any suggestions would be great. Also wondering if a +225 core clock and +450 memory clock is decent enough to be worth keeping with good temps.
<MODERATOR EDIT FOR PROFANITY!>
THIS IS A FAMILY-FRIENDLY WEBSITE ... PROFANITY IS STRICTLY FORBIDDEN AND IS A BANNING OFFENSE!
WATCH YOUR LANGUAGE!
