Hi guys, looking for an expert/experianced persons knowledge to trouble shoot this problem I've been having over the years.
To best surmise my problem.
So my questions are:
1. Is it the PCI wifi adapter's fault? I say this because sometimes it works fine but other times it behaves like trash. I'm more and more suspecting that this cheap TP link is at fault.
I've attached a speed test result, you can see how the D/L speed varies which I'm pretty sure makes it lag.
http://i62.tinypic.com/2ueiflj.jpg
2. What tests can I do to try determine the root cause? I've been trying ping testers, they don't really help unless they graph the results. I might try facing my pc case better but I still think it's the cards problem.
3. I'm thinking getting a new wifi adapter. Should I go for a usb wifi since I could plug it in the front of the case which faces the wifi best? Or are all usb's bad and I should focus rearranging the new PCI card towards the wifi?
Thanks for reading and I'll answer all questions the best I can.
I have a TP link PCI wifi card installed in my pc case.
http://www.mwave.com.au/product/tplink-tlwn881nd-300mbps-wireless-n-pci-express-adapter-aa81105
The Case is under a table facing away from the wifi/modem about 6m away, one wall between it and my room.
I have times the wifi works well, and times like this that I want to hammer the tiny $19 PCI wifi thing. The best of times I can play all my games without any lag, ping 50-80.
The worst of times, it disconnects from the wifi and I have to manually reconnect.
The main problem when it plays up is that I experience regular "clogging" in the online games I play. For example I play cs:go regularly, now, I've run the +graph command which shows my ping (probably sampling 10 times a second). The ping will stay at 50ms then spike to 250 then slowly drop down to 50 again. I'm certain it's a delay in sending or receiving the information as in game everything freezes briefly.
I've tried changing wifi settings too, the 20mhz , to 40mhz upper and lower. and also changing channel to the least popular. Sometimes it just makes things even worse. The main point is, my brothers laptop can play those games quite fine, being even further away from the wifi than me.
