I REALLY REALLY thought I fixed all my latency problems... But I guess not.
So recently I was having major stuttering in games. Big time in PUBG, and some in Apex.
I updated my realtek audio drivers and that seemed to completely fix the issue in PUBG. I figured since it was worst in pubg and is now gone, then it must be gone completely.
But I was wrong, started playing apex the other day and boom getting the same stuttering/ micro freezing that I was getting before.
Let me know if I'm missing anything here in the latency mon test info. For the most part my latency stays low, but randomly spikes up, usually causing frames to stutter.
Heres the latencymon info:
_
CONCLUSION
_
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:09:52 (h🇲🇲ss) on processors 0,1,2 and 3.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP-KV3ASTT
OS version: Windows 10 , 10.0, build: 17134 (x64)
Hardware: ASRock, Z390 Phantom Gaming 4
CPU: GenuineIntel Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
Logical processors: 8
Processor groups: 1
RAM: 16232 MB total
_
CPU SPEED
_
Reported CPU speed: 360 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
_
MEASURED INTERRUPT TO USER PROCESS LATENCIES
_
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 820.053567
Average measured interrupt to process latency (µs): 3.424657
Highest measured interrupt to DPC latency (µs): 816.924677
Average measured interrupt to DPC latency (µs): 1.293529
_
REPORTED ISRs
_
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 185.413889
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.245688
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.251329
ISR count (execution time <250 µs): 920240
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 704.236667
Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 0.118718
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.361890
DPC count (execution time <250 µs): 3265425
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 5
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: system
Total number of hard pagefaults 19513
Hard pagefault count of hardest hit process: 16678
Number of processes hit: 22
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 42.933908
CPU 0 ISR highest execution time (µs): 185.413889
CPU 0 ISR total execution time (s): 11.785710
CPU 0 ISR count: 808037
CPU 0 DPC highest execution time (µs): 704.236667
CPU 0 DPC total execution time (s): 14.049975
CPU 0 DPC count: 2981300
_
CPU 1 Interrupt cycle time (s): 22.745884
CPU 1 ISR highest execution time (µs): 121.983333
CPU 1 ISR total execution time (s): 0.116551
CPU 1 ISR count: 111468
CPU 1 DPC highest execution time (µs): 270.630
CPU 1 DPC total execution time (s): 2.967252
CPU 1 DPC count: 245741
_
CPU 2 Interrupt cycle time (s): 11.756905
CPU 2 ISR highest execution time (µs): 9.039444
CPU 2 ISR total execution time (s): 0.001005
CPU 2 ISR count: 735
CPU 2 DPC highest execution time (µs): 140.128333
CPU 2 DPC total execution time (s): 0.076096
CPU 2 DPC count: 20939
_
CPU 3 Interrupt cycle time (s): 10.298891
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 135.567222
CPU 3 DPC total execution time (s): 0.046231
CPU 3 DPC count: 17450
_
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
Processor groups: 1
RAM: 16232 MB total
_
CPU SPEED
_
_
_
_
REPORTED ISRs
_
_
REPORTED DPCs
_
_
_
_
PER CPU DATA
_
_
_
_
CPU 3 ISR count: 0
_
