High Ping between PC and Wireless Router
specx
19
I recently bought a new wifi router. My problem is at random times ping spikes will occur. When this ping spikes happen I tried pinging my router and get pings from 300 to 5000. This is unnoticeable while browsing but while gaming this is an annoyance. My ping is a steady 32 then suddenly a ping spike will occur. I tried connecting my laptop directly to the router using an ethernet cable but nothing changes. If i don't use the router and i connect my laptop directly to the modem my ping is stable, so i am sure that the problem is with my router. There are 2 computers connected to the router. I'll provide my router configs.
milli i think. I used cmd to ping. Yes i am pinging 192.168.7.1. Yes it happens to both PCs. I have no idea where to get the firmware of this router.
nothing is found in the upgrade firmware section. How do i factory reset? there is only one button on the router and it says rst/wps. is that it?
