High ping problem in CS GO
nrsaShubham
Commendable
Aug 3, 2017
70
I am facing high ping problem while playing CS GO..I have 5mbps ( actually my connection is 10mbps but i got only 5mbps due to high distance from ISP) broadband connection ...and i am getting always more than 120ms ping..i checked with ISP too thay are saying no problem from their side...I tried to play with my mobile LTE hotspot ( 15-25 mbps download,3- 8 mbps upload)..but still i get 80+ ping which is fluctuating on hotspot connection from 80 to 1000 ms...so not playable.....
i cant change my ISP as my city is small and have only 2 ISP ...second one has highest 4mbps connection with very limited free data with higher price...
Pings are fine on the BB-infrastructure (218.248.224.0 - 218.248.239.255). However once you go through BSNL-1593266-Mumbai (59.144.105.40 - 59.144.105.43) which obviously is very small with a very slow link, then your pings are unacceptable. The next hop is BHARTI-IN (Airtel 182.64.0.0 - 182.79.255.255) and they are quite large with excellent bandwidth. Contact your ISP and ask the reason why they go through BSNL-1593266-Mumbai since they are a serious bottleneck. They probably can reconfigure their routers to use a better backbobe.
nrsaShubham
Commendable
Aug 3, 2017
70
1 84 ms 208 ms 207 ms 10.202.0.1
2 85 ms 212 ms 202 ms 172.17.42.1
3 84 ms 206 ms 207 ms 139.59.16.254
4 88 ms 205 ms 204 ms 138.197.249.18
5 85 ms 212 ms 206 ms 202.56.198.29
6 91 ms 219 ms 215 ms 182.79.243.83
7 * * * Request timed out.
8 * * * Request timed out.
9 119 ms 176 ms 208 ms 72.14.242.178
10 92 ms 212 ms 217 ms 216.239.56.32
11 126 ms 245 ms 244 ms 216.239.48.227
12 124 ms 167 ms 209 ms 64.233.174.109
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 123 ms 243 ms 243 ms google-public-dns-a.google.com [8.8.8.8]
nrsaShubham
Commendable
Aug 3, 2017
70
Yes PC is directly connected to Modem via Ethernet cable...
Is is problem with ISP...As my broadplan is of 10mbps...but getting only 5mbps....ISP customer care says that my house is very far (8 km) from their office and they are using copper wire(landline) for internet...and copper wire has loss as the distance is increase...but i am getting just half of bandwidth ...is this acceptable reason ?? i know copper wire connection has loss but that much loss...?
or have problem with my Modem?
look at Attenuation and SNR margin i am getting
Adsl Line Status SHOWTIME.L0
Adsl Mode G992.5
Up Stream 509 kbps
Down Stream 5214 kbps
Attenuation Down Stream 52
Attenuation Up Stream 35
SNR Margin Down Stream 8.1
SNR Margin Up Stream 21.1
nrsaShubham
Commendable
Aug 3, 2017
70
No, I dont have another pc for test..yes i have a very old laptop which cant run csgo...
I tried speedtest on speedtest.net....and my speed is always in between 4.5 - 5 mbps
On a 2.2 Mbps ADSL link, I get 69-75 ms pings (SpeedTest to my ISP). Since your link is twice as fast, I would expect pings to your ISP to be about half. Can't you use the old laptop to run "tracert 8.8.8.8"? It may not be fast enough for csgo, but a tracert requires little CPU resources.
nrsaShubham
Commendable
Aug 3, 2017
70
ok i will try on my old laptop and post the result tomorrow
nrsaShubham
Commendable
Aug 3, 2017
70
Here is screenshot of Tracert 8.8.8.8 on my laptop...(3 times)
https://imgur.com/a/Cwgx5
Your pings are a bit higher than expected, but it may be normal in India. What's interesting is the lower pings when using the old laptop; a more powerful desktop should definitely be as good or better. The laptop is connected to bsnl.in and Google is 8 hops away. In the tracert that you provided earlier, the desktop is connected via a VPN and Google is 23 hops away; no wonder the pings are high. What are the results of a "tracert 8.8.8.8" from the desktop is it's connected directly to your ISP like the laptop instead of using a VPN?
nrsaShubham
Commendable
Aug 3, 2017
70
Bro i am not using VPN on desktop...I need to check again my internet configuration....At that time i think i have speedify software installed ( for combining speed of my dsl 4-5mbps and my mobile hotspot LTE 15-25 mbps for gaming+streaming but it doesnt work because of very high ping during streaming) ..May be due to that reason it shows vpn...i uninstalled it 2 days before....i am posting new result
C:\>tracert 8.8.8.8
Tracing route to google-public-dns-a.google.com [8.8.8.8]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 37 ms 37 ms 36 ms static.ill.218.248.61.210/24.bsnl.in [218.248.61.210]
3 55 ms 55 ms 55 ms 218.248.235.197
4 55 ms * 54 ms 218.248.235.198
5 55 ms 54 ms 57 ms 74.125.48.138
6 62 ms 60 ms 60 ms 108.170.248.209
7 54 ms 52 ms 53 ms 209.85.255.5
8 55 ms 52 ms 53 ms google-public-dns-a.google.com [8.8.8.8]
Trace complete.
Still cs-go ping is 220+
And bro i dont think high ping is normal in india ...Actually i am using a Government owned ISP company (BSNL) ...because i live in small city and their is no other ISP available..thatswhy i needed to stic with BSNL..even i am getting half speed of what i am paying for ( Paying for 10mbps connection and getting only 4.5-5 mbps due to distance from ISP around 7-8 km...Attenuation is 52 for my link which is very high)
many of my friend living in other big cities in india getting 30-50 ping in cs go using private ISP
I think i got a worst ISP
The above pings are acceptable. A ping to your ISP (218.248.61.210) is fine at 37 ms, but the link from your ISP to the backbone (218.248.235.197) is too slow.
Are you connecting to a cs:go server near you or one that's across the ocean? Your ISP can't do much for you if you connect to a server in other countries. Did you perform a tracert to the cs:go server to figure out where it is? You can use https://www.ultratools.com/tools/ipWhoisLookupResult to find out who owns an IP address.
nrsaShubham
Commendable
Aug 3, 2017
70
Bro i am connected to Asia server (india is in Asia)
server ip 45.121.184.147:27028
Tracert result for following ip ( 2 times test)
C:\>tracert 45.121.184.147
Tracing route to 45.121.184.147 over a maximum of 30 hops
1 <1 ms 1 ms 1 ms 192.168.1.1
2 35 ms 72 ms 35 ms 218.248.165.126
3 63 ms 63 ms 62 ms 218.248.235.157
5 235 ms 235 ms 234 ms aes-static-041.105.144.59.airtel.in [59.144.105.41]
6 303 ms 300 ms 320 ms 182.79.178.198
7 285 ms 286 ms 285 ms 182.79.181.3
8 259 ms 260 ms 260 ms 182.79.201.235
9 357 ms 298 ms 288 ms 182.79.255.14
10 322 ms 324 ms 321 ms aes-static-086.1.22.125.airtel.in [125.22.1.86]
11 353 ms 419 ms 346 ms 192.168.152.7
12 329 ms 330 ms 329 ms 45.121.184.147
Trace complete.
2 36 ms 37 ms 36 ms 218.248.165.126
3 62 ms 62 ms 62 ms 218.248.235.157
4 61 ms * * 218.248.235.158
5 548 ms 551 ms 546 ms aes-static-041.105.144.59.airtel.in [59.144.105.41]
6 611 ms 590 ms 618 ms 182.79.178.198
7 601 ms 600 ms 604 ms 182.79.181.3
8 576 ms 577 ms 577 ms 182.79.201.235
9 301 ms 296 ms 284 ms 182.79.255.14
10 324 ms 325 ms 324 ms aes-static-086.1.22.125.airtel.in [125.22.1.86]
11 349 ms 344 ms 347 ms 192.168.152.7
12 325 ms 325 ms 324 ms 45.121.184.147
Trace complete.
Look at that pings....
Is their any way to find best server ip for me and changes it in cs go...Actually i am very new in CS GO...i never played Counter strike series before...i only spent 42 hour till now..
