High Ping, Very low download speed
gigaaa2
4
Its only on my computer. i already tried another cable but still doesnt fix it.
Speedtest on my mobile have a normal result of how my net should be. Its only here on my pc.
This is my previous result (The normal one)
Download Speed : 3.04 Mb/s
Upload Speed : 0.81 Mb/s
Ping : 15 ms
But this is my newest result where my results are horrible.
Download Speed : 0.67 Mb/s
Upload Speed : 0.16 Mb/s
Ping : 358 ms
Does this have something to do with my built in LAN Card on motherboard?
What should i do? Internet is working properly on other device
reinstall drivers, try different ethernet port on router, try different router, try pluggin the ethernet straight into the modem and not the router, etc. You need to isolate the problem, then deal with it.
I think so.. Only my computer is connected directly while my Mobile which had a normal result is connected via wifi.
its like 10-20ft.
You should check your network performance. The easiest way is to go to www.netscan.co and start a network scan.
netscan.co is a web application that will perform a series of network tests for modern Web Services like WebSockets, WebRTC and XHR.
Additionally a full profile of your browser, operating system and environment will be generated. After the scan is done you will be given a unique url, please share it back so we can help you.
