I've been having trouble with my system for some time now. I've checked everything i've been told to and I am pretty sure I have narrowed it down to my motherboard.
Before I get too in depth on it, here is my setup.
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels PCI Interface Sound Card
Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate Barracuda 7200.10 ST3320620AS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive
AMD Athlon 64 X2 5400+ Windsor 2.8GHz Socket AM2 Dual-Core Processor
EVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16
Thermaltake Purepower W0129RU ATX12V 600 W Power Supply
Please excuse my lack of knowledge on the subject area.
I'm using the GIGABYTE GA-M59SLI-S5 AM2 NVIDIA nForce 590 SLI MCP ATX motherboard
The problem is sort of a winding, high pitched type noise. It comes and goes but changes based on whatever I am doing. For example, if I were to scroll down this page the noise would elevate it's pitch.
I've been able to live with it for a few months but today I
was capturing some audio from a vinyl record and it captured the noise with the track. So now I have a track that has this same wheezing noise in the background. It's been bearable until now but this seems like a roadblock. Is there something I can do to test the motherboard and verify that it is coming from there?
I have checked the processor, case fans, power supply fan, chipset fan, video card fan and I know for sure it is not any of those things.
Is it possible that a capacitor has gone bad and is making the noise? It seems odd that it would change it's pitch based on what task I am working on at the time.
Any ideas would be appreciated.
This is an example of the noise that I was able to record. You can hear me click a few times on some tabs part way into the sound file.
http://www.supload.com/listen?s=ZJHEWVIYQ3ZQ
