I just build my first system with a i5 2500k, p8z68-v le, and swapped an 8 month old CX600 Corsair PSU from my old rig. Before slapping the side panel on after installing w7 I noticed there was a high pitched electrical sound, while the computer was off. The side panel was off and i was sitting near the case on the floor and heard it concerned. I never heard it from my old pc but I just plugged and played when i first got it and didn't even stop to look at it, so it's tough to know whether or not the sound was present before.
Here is what i've found out:
Performed the PSU paperclip test- fan runs after flipping the switch, good.
PSU plugged into wall w/ switch off, no paperclip- no sound. Turn switch on, different noise more like a click instead of a constant noise.
PSU plugged into wall w/ switch off, paperclip- no sound. Turn switch on, fan boots up, high pitched sound comes on. Turn switch off, noise persists for maybe a few minutes then goes off.
PSU plugged into MOBO and running, sound is present for the first few minutes of operation. While plugged into the computer its high pitched sound sounds almost like morse code...
I may just be being overzealous, but I'd rather not use a PSU that may damage my equipment................ Let me know if i'm being a tool,
Thank you!!!
Thank you!!!
