I am having a problem achieving a viewable resolution...
Here are the components i'm using:
Sanyo 26" LCD HDTV: http://www.overstock.com/Electronic...CD-HMDI-HDTV-Refurbished/2897272/product.html
AIT 5570 made by ASUS: http://www.newegg.com/Product/Produ...&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
They are hooked up using this HDMI cable: http://www.newegg.com/Product/Produ...&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
The "recommended" settings are 1280x760 running at 59-60 hertz. When I try to scale the resolution beyond that, even one setting, (1920x1080 is what I would ideally use) the hertz drop to 20-30(interlaced), and parts of my screen begin flickering. Is there any known fix/tweak to this other than buying a new monitor? There is no VGA hookup on my TV, if that is a known fix.
