High Speed Fan Suggestion for Over heating PC ?!!
ajaymishere
17
can anyone suggest me some high speed fans to add to my pc cabinet ?!!
its getting overheated as my ambient temp is 30 degree Celsius !! im worried about the HDDs as they are getting hot after some time !!
Specs
i7 4790k
GTX 970
16GB Corsair venge pro
120 GB SAMSUNG EVO
2 TB WD GREEN
1 TB SEGATE
If your hard drives are running hot then there are big chances they will die early. But don't worry all you need is hard drive fans and some cabinet fans.
Hard disk fan: http://www.homeshop18.com/deepcool-icedisk-2-3-5-hard-disk-cooler/computers-tablets/laptop-accessories/product:30547599/cid:16303/?gclid=Cj0KEQiAjMC2BRC34oGKqY27jtkBEiQAwSXzfmAqBWNBV18wUybVHtYl3V5ViDXPVsogM6NaF8dkPGoaAuor8P8HAQ
Cabinet fans:http://www.amazon.in/Circle-Stay-Cool-C-12-Cabinet/dp/B00N3V8JME/ref=pd_sim_147_8?ie=UTF8&dpID=51xnsKsEJpL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=09PTE2GMME49R7T3AXJM
(I am guessing you are from India)
The Deepcool hard disk cooler was available in amazon.in for just 300 INR, but it went out of stock. You can wait till it...
The Deepcool hard disk cooler was available in amazon.in for just 300 INR, but it went out of stock. You can wait till it restocks. I found other hard disk coolers overpriced. Make sure your cabinet has empty hard disk slots to fit the hard disk coolers. Your SSD doesn't need cooling.
