Hi All,
I am seeing higher than expected temperatures on the 9800X3D with an AIO.
1. Cinebench R23.2 Multicore test, CPU temps hit 93 C in just a few mins,
2. During Hogwarts Legacy, Shader Cache rebuild, CPU temperature spikes to 95C, fans revving like a jet engine
3. Idle Temperature hovers around 53 ~ 55C,
I just recently got the AIO and the CPU, but am wondering if the AIO is damaged, or is it a case airflow issue.
Can you please suggest a solution ?
This is my system config:
- CPU: Ryzen 7 9800X3D installed with a Thermalright AM5 CPU holder, and TF7 thermal paste
- AIO: Cooler Master ML360L Top mounted, fans set to exhaust,
- AIO Pump connected to sys_fan header, set to 100%
- AIO Fans connected to CPU PWM Header
- Motherboard: Asus Prime B650M-R
- Case: Asus Prime AP201, with tempered glass cover (Installed Mesh in the front, and tempered glass on the rear)
- Other Fans: Rear mounted 120mm as intake , no bottom fans for the GPU
- GPU: Sapphire Radeon 9070XT
- RAM: 32 GB
- PSU Corsair RM1000e
- RAM: 32 GB
