High temps after applying thermal paste
dannyroose2001
18
Hi, I've replaced the thermal paste on my cpu and noticed my temps go super high after doing so (99c) I've tried re applying the paste 5 or 6 times now, no difference. What maybe the problem? My method of applying the paste or? My application method is just a half a pea size blob then diagonally screening the cooler on top.
Specs are GTX 980, i7 4790k, Corsair H55, Z97-g55 SLI
Are you sure the fan is working?
Did you clean the CPU and Heatsink between each application?
I use my own application method that I call 'Wet Blob'
Put a half grain of rice on both of the heatspreaders.
Use a piece of paper to spread it around with your finger tip.
Press hard, cover everything and 99% of it will rub off.
You just want to get the surfaces wet and fill the micro pores.
Then use the normal blob.
I find I get 100% coverage, with no extra and good temps.
Good job diagnosing the problem!
I hope you can return the water cooler to be fixed. I really don't know much about those things.
Can you get a temporary air cooled heat sink until you get a new AIO?
I've gotten a cooler master tx3, trying to get the back place off f the old one now but when I try and unscrew the last one the back plate screw is moving with it so I can't get the thing off
