Question High temps and strange noises
matty.kemp
25
about a month ago i got a pc from pc specialist with a 2060 super. and since it came out of the box the gpu sometimes makes fairly loud whining sounds while under load that fade in and out. The gpu idles at around 50°C and goes anywhere between 77-83°C while under load with the fans around 60-70% speed according to msi afterburner. The card is also fairly loud at these speeds when people i know who have this card said it is quiet. I dont have a problem with the noises as long as it is not a sign something will go wrong in the future and i just want to make sure that this wont affect performance in games either. (Sorry if this paragraph is a mess im tired) Also on another note, is there a benchmarking software that i can enter my specs into that predicts what score i should be getting and compare it to what i get? Just worried that my pc isnt performing as expected some how and i want to make sure everything is good while im still under warranty. Thanks again
Phaaze88
Dignified
Herald
Sounds like coil whine.
Idle temp is normal.
83C is thermal throttle temp, so it makes sense the fans would be running that high.
Post the PC's full specs, please - or you can do 1 of the following instead:
1)https://www.userbenchmark.com/
Post the link to your results - it'll contain most of the PC's specs, save for the case and power supply make and model, so if you could provide that as well...
2)Download and run HWINFO: https://www.hwinfo.com/
Leave the 2 checkboxes unchecked and click Run.
Click on Save Report, Summary for Clipboard, and then Next.
Highlight everything that appears in the new window and copy-paste it here.
Again, the case and power supply make and model aren't included, so if you can please provide that...
Karadjgne
Herald
Sounds like a fan that has bad bearings, at certain rpms it'll make a racket. Sorta like a tire that's out of balance only gets really bad at certain mph, but smooths out below/above that speed range.
Pop the side panel and during that noise period it'll be obvious as to whether it's coil whine, which is a higher pitched nails on a chalkboard noise, or fan bearings which are a lower pitched thrumm sound.
matty.kemp
25
thanks for the response, here are the results from user benchmark
UserBenchmarks: Game 109%, Desk 152%, Work 126%
CPU: Intel Core i7-9700K - 101.8%
GPU: Nvidia RTX 2060S (Super) - 99.4%
SSD: Samsung 970 Evo Plus NVMe PCIe M.2 500GB - 305.6%
HDD: Seagate Barracuda 1TB (2016) - 112.9%
RAM: Corsair CM4X8GD3000C16K4D 2x8GB - 94.5%
MBD: PC Intel Z370
and my case is the 'CORSAIR OBSIDIAN SERIES™ 500D SE CASE'
and psu 'CORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET '
The results from the test were fine but the temperature barely increased throughout any of the test
matty.kemp
25
i didnt think it sounded like coil whine i was hearing in videos but i was just assuming thats what it was its like a buzzing sound that fades in and out almost like electric hair clippers or something
Karadjgne
Herald
If it's sounding like a buzzing, I'd do a good inspection of the fans, it could be a wire hitting the blades under the shroud, or even a piece of packing or dirt that's stuck under the shroud. If something is actually hitting the blades, it can slow them down, which will decrease airflow across the heatsink, thereby allowing higher temps.
Phaaze88
Dignified
Herald
:whistle:
Nice!
Nothing particularly stands out as odd there.
I'd suspect you're not running into temp issues with the 2060 Super in the short term, but long term sessions where at 83C(default thermal limit) the gpu fans really get cranking.
Have you already experimented with custom fan curves via Msi Afterburner or EVGA Precision X?
You should check the fans as Karadjgne suggested to be sure.
