High Temps with 4690k and Noctua NH D15
Shaan5
577
I ran a blend in prime95 for 8 Mins and here is what I got. No overclocking has been done
Core 1: 60
Core 2: 62
Core 3: 63
Core 4: 57
Is this normal, I'm freaking out right now
The CPU Idles at 25-35 Degrees
Thanks in advance
Prime 95 is over stressful and only v26.6 should be used on Haswell CPUs. And then only for OC testing.
Core temp is 5C higher than CPU temp
CPU temps should be 40C max at idle and 60C max gaming.
Yours is 55C stress testing which should be 80C max. So you are more than fine.
Dont worry. Haswell can take alot of heat. Commonly accepted safe limit is under 80° during stress test. Under 75° is even considered conservative... Thermal throtteling kicks in only at 105°. Some have run theirs at above 90° idle for months without knowing (lol i know) and without killing it...
I use Real Temp for checking and recording temps
Core 1: 60
Core 2: 62
Core 3: 63
Core 4: 56
The temps progressively rised and peaked at 8 mins before plummeting back down tp the 50's. They rose back to around 60 at the 16 Minute mark but never exceded their original peak temps, within a minute, they fell back down to the 40's and Stayed there
The Voltage was around 1.106 V
