Question High utilisation but low temps
CrossbredLemon
Commendable
Sep 5, 2020
7
Hi,
I've had a google but the only thing I can come across thats similar is this post from 2014
And rolling back my driver/re-installing, hasn't done anything to improve the situation.
I've done malware scan, clean.
Nothing stands out as odd in processes/services
And my tower is as dust free as can reasonably be.
Basically, a short while after playing a game, fan ramps up for what feels like a not very long time. Then temps sit low, utilisation sits high, fps lies face down in the dirt.
PC Specs are
AMD 5800X
32GB of 2400MHz Ram
MSI RTX 3070
Havent got a clue whats going on. Even when i stick on DLSS and the graphics are basically colourful triangles i still get a tanked FPS.
sorry if the below is messy, I stuck the end of a GPU-Z log there.
heres the full txt file if its useful
Date , GPU Clock [MHz] , Memory Clock [MHz] , GPU Temperature [°C] , Hot Spot [°C] , Fan 1 Speed (%) [%] , Fan 1 Speed (RPM) [RPM] , Fan 2 Speed (%) [%] , Fan 2 Speed (RPM) [RPM] , Memory Used [MB] , GPU Load [%] , Memory Controller Load [%] , Video Engine Load [%] , Bus Interface Load [%] , Board Power Draw [W] , GPU Chip Power Draw [W] , PWR_SRC Power Draw [W] , PWR_SRC Voltage [V] , PCIe Slot Power [W] , PCIe Slot Voltage [V] , 8-Pin #1 Power [W] , 8-Pin #1 Voltage [V] , 8-Pin #2 Power [W] , 8-Pin #2 Voltage [V] , Power Consumption (%) [% TDP] , PerfCap Reason [] , GPU Voltage [V] , CPU Temperature [°C] , System Memory Used [MB] ,
2023-08-17 22:19:41 , 1935.0 , 1750.2 , 61.2 , 72.1 , 35 , 1128 , 35 , 1132 , 7343 , 100 , 8 , 0 , 1 , 98.6 , 70.0 , 28.6 , 12.0 , 15.8 , 12.1 , 45.2 , 12.1 , 37.3 , 12.1 , 44.8 , 4 , 1.0680 , 40.6 , 25254 ,
2023-08-17 22:19:43 , 1935.0 , 1750.2 , 61.0 , 71.7 , 35 , 1129 , 35 , 1132 , 7327 , 100 , 11 , 0 , 5 , 82.1 , 54.7 , 27.4 , 12.0 , 12.8 , 12.1 , 38.7 , 12.1 , 30.3 , 12.1 , 46.7 , 4 , 1.0680 , 41.3 , 25237 ,
2023-08-17 22:19:43 , 1935.0 , 1750.2 , 62.1 , 73.1 , 35 , 1129 , 35 , 1128 , 7334 , 100 , 13 , 0 , 3 , 104.8 , 75.1 , 29.7 , 12.0 , 16.9 , 12.1 , 47.8 , 12.1 , 39.8 , 12.1 , 44.3 , 4 , 1.0680 , 41.5 , 25246 ,
2023-08-17 22:19:44 , 1935.0 , 1750.2 , 61.6 , 72.4 , 35 , 1128 , 35 , 1128 , 7334 , 100 , 12 , 0 , 2 , 116.2 , 85.4 , 30.9 , 12.0 , 18.9 , 12.1 , 52.2 , 12.1 , 35.5 , 12.1 , 42.8 , 4 , 1.0680 , 41.3 , 25243 ,
2023-08-17 22:19:45 , 1935.0 , 1750.2 , 61.3 , 72.3 , 35 , 1128 , 35 , 1128 , 7345 , 100 , 12 , 0 , 1 , 103.4 , 73.9 , 29.5 , 12.0 , 16.6 , 12.1 , 47.2 , 12.1 , 39.2 , 12.1 , 47.0 , 4 , 1.0680 , 41.3 , 25252 ,
2023-08-17 22:19:46 , 1935.0 , 1750.2 , 60.9 , 71.7 , 35 , 1131 , 35 , 1129 , 7336 , 100 , 9 , 0 , 1 , 104.1 , 75.1 , 29.1 , 12.0 , 16.7 , 12.1 , 47.4 , 12.1 , 36.7 , 12.1 , 44.1 , 4 , 1.0680 , 41.1 , 25247 ,
2023-08-17 22:19:48 , 1935.0 , 1750.2 , 61.4 , 72.0 , 35 , 1129 , 35 , 1131 , 7336 , 100 , 18 , 0 , 7 , 103.6 , 74.0 , 29.6 , 12.0 , 16.7 , 12.1 , 42.9 , 12.1 , 34.7 , 12.1 , 42.0 , 4 , 1.0680 , 41.0 , 25253 ,
2023-08-17 22:19:48 , 1935.0 , 1750.2 , 62.7 , 73.7 , 35 , 1129 , 35 , 1129 , 7336 , 100 , 16 , 0 , 3 , 126.5 , 94.8 , 31.7 , 12.0 , 20.8 , 12.1 , 56.4 , 12.1 , 49.0 , 12.1 , 57.5 , 4 , 1.0680 , 40.9 , 25252 ,
2023-08-17 22:19:49 , 1935.0 , 1750.2 , 60.8 , 71.5 , 35 , 1131 , 35 , 1129 , 7336 , 100 , 8 , 0 , 1 , 95.8 , 67.2 , 28.7 , 12.0 , 17.1 , 12.1 , 48.0 , 12.1 , 40.2 , 12.1 , 48.0 , 4 , 1.0680 , 40.6 , 25253 ,
2023-08-17 22:19:50 , 1935.0 , 1750.2 , 61.3 , 72.1 , 35 , 1130 , 35 , 1129 , 7338 , 100 , 11 , 0 , 1 , 104.8 , 75.4 , 29.4 , 12.0 , 16.9 , 12.1 , 47.7 , 12.1 , 39.9 , 12.1 , 49.0 , 4 , 1.0680 , 40.6 , 25254 ,
2023-08-17 22:19:51 , 1935.0 , 1750.2 , 61.1 , 71.9 , 35 , 1131 , 35 , 1128 , 7337 , 100 , 7 , 0 , 1 , 98.4 , 66.6 , 27.9 , 12.0 , 14.8 , 12.1 , 43.7 , 12.1 , 35.6 , 12.1 , 42.9 , 4 , 1.0680 , 40.6 , 25251 ,
2023-08-17 22:19:52 , 1935.0 , 1750.2 , 62.8 , 73.8 , 35 , 1130 , 35 , 1131 , 7340 , 99 , 14 , 0 , 1 , 185.7 , 148.5 , 37.3 , 12.0 , 18.4 , 12.1 , 50.8 , 12.1 , 43.4 , 12.1 , 51.4 , 4 , 1.0680 , 40.9 , 25253 ,
2023-08-17 22:19:53 , 1935.0 , 1750.2 , 62.3 , 73.2 , 35 , 1130 , 35 , 1130 , 7339 , 100 , 12 , 0 , 1 , 107.7 , 78.6 , 29.1 , 12.0 , 17.5 , 12.1 , 48.7 , 12.1 , 41.2 , 12.1 , 49.0 , 4 , 1.0680 , 40.9 , 25255 ,
2023-08-17 22:19:54 , 1935.0 , 1750.2 , 62.3 , 73.1 , 35 , 1131 , 35 , 1129 , 7339 , 100 , 9 , 0 , 1 , 100.0 , 71.2 , 28.8 , 12.0 , 16.0 , 12.1 , 45.7 , 12.1 , 38.0 , 12.1 , 45.4 , 4 , 1.0680 , 40.8 , 25254 ,
2023-08-17 22:19:55 , 1935.0 , 1750.2 , 62.0 , 73.1 , 35 , 1128 , 35 , 1128 , 7338 , 100 , 12 , 0 , 1 , 111.5 , 81.7 , 29.8 , 12.0 , 18.2 , 12.1 , 50.9 , 12.1 , 43.5 , 12.1 , 51.5 , 4 , 1.0680 , 40.6 , 25254 ,
2023-08-17 22:19:56 , 1935.0 , 1750.2 , 62.0 , 72.8 , 35 , 1130 , 35 , 1127 , 7338 , 100 , 10 , 0 , 3 , 107.0 , 77.4 , 29.6 , 12.0 , 17.1 , 12.1 , 51.8 , 12.1 , 44.6 , 12.1 , 52.6 , 5 , 1.0680 , 40.6 , 25254 ,
2023-08-17 22:19:57 , 1935.0 , 1750.2 , 62.6 , 73.5 , 35 , 1129 , 35 , 1128 , 7337 , 100 , 11 , 0 , 1 , 108.2 , 78.5 , 29.7 , 12.0 , 17.5 , 12.1 , 48.9 , 12.1 , 41.5 , 12.1 , 49.2 , 4 , 1.0680 , 40.6 , 25254 ,
2023-08-17 22:19:58 , 1935.0 , 1750.2 , 62.3 , 73.3 , 35 , 1129 , 35 , 1131 , 7337 , 100 , 12 , 0 , 2 , 118.8 , 88.3 , 30.5 , 12.0 , 19.6 , 12.1 , 53.1 , 12.1 , 45.8 , 12.1 , 54.0 , 4 , 1.0680 , 40.5 , 25255 ,
2023-08-17 22:19:59 , 1935.0 , 1750.2 , 62.6 , 73.5 , 35 , 1128 , 35 , 1134 , 7347 , 100 , 11 , 0 , 1 , 108.3 , 78.4 , 29.9 , 12.0 , 17.6 , 12.1 , 51.8 , 12.1 , 44.4 , 12.1 , 52.5 , 4 , 1.0680 , 40.5 , 25255 ,
2023-08-17 22:20:00 , 1935.0 , 1750.2 , 62.8 , 73.8 , 35 , 1128 , 35 , 1131 , 7335 , 100 , 13 , 0 , 2 , 112.4 , 82.6 , 29.8 , 12.0 , 18.4 , 12.1 , 50.5 , 12.1 , 43.2 , 12.1 , 51.1 , 4 , 1.0680 , 40.8 , 25255 ,
2023-08-17 22:20:01 , 1935.0 , 1750.2 , 62.0 , 72.9 , 35 , 1131 , 35 , 1131 , 7335 , 100 , 12 , 0 , 1 , 101.2 , 88.3 , 30.4 , 12.0 , 19.5 , 12.1 , 53.0 , 12.1 , 45.8 , 12.1 , 53.9 , 4 , 1.0680 , 40.6 , 25257 ,
2023-08-17 22:20:02 , 1935.0 , 1750.2 , 62.5 , 73.5 , 35 , 1129 , 35 , 1131 , 7334 , 99 , 9 , 0 , 1 , 108.1 , 78.8 , 29.2 , 12.0 , 17.5 , 12.1 , 48.8 , 12.1 , 41.5 , 12.1 , 49.1 , 4 , 1.0680 , 40.5 , 25256 ,
2023-08-17 22:20:03 , 1935.0 , 1750.2 , 65.0 , 76.3 , 35 , 1132 , 35 , 1131 , 7330 , 100 , 11 , 0 , 1 , 113.5 , 83.3 , 30.2 , 12.0 , 18.6 , 12.1 , 50.9 , 12.1 , 43.7 , 12.1 , 51.6 , 4 , 1.0680 , 40.8 , 25261 ,
2023-08-17 22:20:04 , 1935.0 , 1750.2 , 62.5 , 73.7 , 36 , 1130 , 35 , 1136 , 7331 , 100 , 11 , 0 , 1 , 106.6 , 77.4 , 29.2 , 12.0 , 17.3 , 12.0 , 48.3 , 12.1 , 40.7 , 12.1 , 48.5 , 4 , 1.0680 , 40.5 , 25263 ,
2023-08-17 22:20:05 , 1935.0 , 1750.2 , 62.0 , 72.9 , 36 , 1135 , 36 , 1131 , 7332 , 100 , 14 , 0 , 7 , 104.8 , 75.4 , 29.4 , 12.0 , 16.8 , 12.1 , 47.6 , 12.1 , 40.0 , 12.1 , 46.2 , 4 , 1.0680 , 41.0 , 25226 ,
2023-08-17 22:20:06 , 1935.0 , 1750.2 , 63.9 , 74.9 , 36 , 1138 , 36 , 1134 , 7335 , 100 , 13 , 0 , 1 , 149.9 , 116.4 , 33.5 , 12.0 , 25.3 , 12.1 , 65.0 , 12.1 , 59.3 , 12.1 , 68.1 , 4 , 1.0680 , 40.9 , 25241 ,
2023-08-17 22:20:08 , 1935.0 , 1750.2 , 62.0 , 72.9 , 36 , 1134 , 36 , 1139 , 7336 , 97 , 16 , 0 , 6 , 106.5 , 76.9 , 29.6 , 12.0 , 17.2 , 12.1 , 48.2 , 12.1 , 40.8 , 12.1 , 48.5 , 4 , 1.0680 , 41.0 , 25234 ,
2023-08-17 22:20:08 , 1935.0 , 1750.2 , 63.4 , 74.4 , 36 , 1136 , 36 , 1133 , 7335 , 100 , 15 , 0 , 2 , 123.0 , 92.1 , 30.9 , 12.0 , 20.3 , 12.2 , 54.6 , 12.1 , 47.8 , 12.1 , 55.9 , 4 , 1.0680 , 41.0 , 25239 ,
2023-08-17 22:20:09 , 1935.0 , 1750.2 , 62.1 , 73.1 , 36 , 1136 , 36 , 1139 , 7333 , 100 , 8 , 0 , 1 , 99.0 , 70.3 , 28.7 , 12.0 , 15.8 , 12.1 , 45.3 , 12.1 , 37.5 , 12.1 , 45.0 , 4 , 1.0680 , 41.0 , 25230 ,
2023-08-17 22:20:10 , 1935.0 , 1750.2 , 63.7 , 74.8 , 36 , 1135 , 36 , 1135 , 7338 , 100 , 25 , 0 , 5 , 144.5 , 111.5 , 33.0 , 12.0 , 24.2 , 12.1 , 63.1 , 12.1 , 56.9 , 12.1 , 65.7 , 4 , 1.0680 , 40.9 , 25244 ,
2023-08-17 22:20:11 , 1935.0 , 1750.2 , 62.1 , 73.1 , 36 , 1141 , 36 , 1139 , 7338 , 100 , 9 , 0 , 1 , 105.1 , 75.7 , 29.4 , 12.0 , 17.0 , 12.1 , 47.7 , 12.1 , 40.1 , 12.1 , 47.8 , 4 , 1.0680 , 40.6 , 25242 ,
2023-08-17 22:20:12 , 1935.0 , 1750.2 , 63.9 , 75.1 , 36 , 1134 , 36 , 1135 , 7338 , 97 , 23 , 0 , 5 , 120.3 , 89.5 , 30.8 , 12.0 , 19.7 , 12.1 , 53.6 , 12.1 , 40.0 , 12.1 , 47.7 , 4 , 1.0680 , 41.0 , 25240 ,
2023-08-17 22:20:13 , 1935.0 , 1750.2 , 62.4 , 73.4 , 36 , 1134 , 36 , 1137 , 7344 , 100 , 9 , 0 , 1 , 107.5 , 77.8 , 29.6 , 12.0 , 17.4 , 12.1 , 48.7 , 12.1 , 41.1 , 12.1 , 48.9 , 4 , 1.0680 , 40.9 , 25244 ,
2023-08-17 22:20:14 , 1935.0 , 1750.2 , 63.4 , 74.6 , 36 , 1142 , 36 , 1144 , 7337 , 100 , 20 , 0 , 4 , 114.9 , 84.6 , 30.3 , 12.0 , 18.8 , 12.1 , 51.5 , 12.1 , 44.2 , 12.1 , 52.2 , 4 , 1.0680 , 41.3 , 25245 ,
2023-08-17 22:20:15 , 1935.0 , 1750.2 , 62.6 , 73.6 , 36 , 1143 , 36 , 1137 , 7334 , 100 , 12 , 0 , 1 , 107.8 , 78.2 , 29.6 , 12.0 , 17.5 , 12.1 , 48.7 , 12.1 , 41.2 , 12.1 , 53.3 , 4 , 1.0680 , 40.9 , 25241 ,
2023-08-17 22:20:16 , 1935.0 , 1750.2 , 63.4 , 74.6 , 36 , 1146 , 36 , 1139 , 7335 , 100 , 12 , 0 , 2 , 94.6 , 66.1 , 28.4 , 12.0 , 15.1 , 12.1 , 43.7 , 12.1 , 35.5 , 12.1 , 43.0 , 4 , 1.0680 , 41.1 , 25249 ,
2023-08-17 22:20:18 , 1935.0 , 1750.2 , 63.0 , 73.9 , 36 , 1140 , 36 , 1144 , 7348 , 99 , 16 , 0 , 2 , 110.4 , 81.0 , 29.5 , 12.0 , 15.6 , 12.1 , 43.5 , 12.1 , 35.6 , 12.1 , 44.0 , 4 , 1.0680 , 41.1 , 25255 ,
2023-08-17 22:20:18 , 1935.0 , 1750.2 , 62.3 , 73.2 , 36 , 1141 , 36 , 1147 , 7348 , 100 , 9 , 0 , 1 , 98.1 , 69.1 , 29.1 , 12.0 , 16.2 , 12.1 , 46.0 , 12.1 , 38.0 , 12.1 , 45.7 , 4 , 1.0680 , 41.1 , 25257 ,
2023-08-17 22:20:19 , 1935.0 , 1750.2 , 62.5 , 73.4 , 36 , 1143 , 36 , 1138 , 7349 , 100 , 9 , 0 , 1 , 98.8 , 70.1 , 28.6 , 12.0 , 15.8 , 12.1 , 45.3 , 12.1 , 37.4 , 12.1 , 44.9 , 4 , 1.0680 , 40.9 , 25257 ,
2023-08-17 22:20:20 , 1935.0 , 1750.2 , 63.2 , 74.3 , 36 , 1143 , 36 , 1142 , 7363 , 100 , 28 , 0 , 9 , 125.5 , 93.4 , 32.1 , 12.0 , 20.6 , 12.1 , 45.0 , 12.1 , 36.9 , 12.1 , 44.4 , 4 , 1.0680 , 40.9 , 25253 ,
2023-08-17 22:20:21 , 1935.0 , 1750.2 , 63.4 , 74.3 , 36 , 1145 , 36 , 1143 , 7359 , 100 , 6 , 0 , 1 , 124.9 , 93.2 , 31.8 , 12.0 , 20.5 , 12.1 , 55.8 , 12.1 , 48.3 , 12.1 , 56.8 , 4 , 1.0680 , 40.9 , 25256 ,
2023-08-17 22:20:22 , 1935.0 , 1750.2 , 61.6 , 72.6 , 36 , 1144 , 36 , 1145 , 7359 , 96 , 9 , 0 , 1 , 85.5 , 57.7 , 27.8 , 12.0 , 13.3 , 12.1 , 45.1 , 12.1 , 37.0 , 12.1 , 44.6 , 4 , 1.0680 , 40.8 , 25254 ,
2023-08-17 22:20:24 , 1935.0 , 1750.2 , 61.1 , 71.9 , 36 , 1146 , 36 , 1145 , 7358 , 100 , 3 , 0 , 1 , 83.1 , 55.8 , 27.3 , 12.0 , 14.5 , 12.1 , 42.3 , 12.1 , 34.8 , 12.1 , 41.8 , 4 , 1.0680 , 41.6 , 25245 ,
2023-08-17 22:20:24 , 1935.0 , 1750.2 , 61.5 , 72.4 , 36 , 1145 , 36 , 1141 , 7375 , 100 , 7 , 0 , 1 , 102.9 , 73.7 , 29.2 , 12.0 , 17.4 , 12.1 , 48.1 , 12.1 , 40.0 , 12.1 , 48.1 , 4 , 1.0680 , 41.4 , 25254 ,
2023-08-17 22:20:26 , 1935.0 , 1750.2 , 61.8 , 72.6 , 36 , 1145 , 36 , 1145 , 7403 , 100 , 16 , 0 , 7 , 97.3 , 64.2 , 28.3 , 12.0 , 14.7 , 12.1 , 42.8 , 12.1 , 34.7 , 12.1 , 42.0 , 4 , 1.0680 , 41.9 , 25257 ,
2023-08-17 22:20:26 , 1935.0 , 1750.2 , 61.7 , 72.5 , 36 , 1145 , 36 , 1146 , 7402 , 100 , 8 , 0 , 1 , 126.9 , 91.6 , 31.4 , 12.0 , 20.3 , 12.1 , 54.8 , 12.1 , 47.5 , 12.1 , 55.9 , 4 , 1.0680 , 41.9 , 25251 ,
2023-08-17 22:20:27 , 1935.0 , 1750.2 , 60.7 , 71.6 , 36 , 1145 , 36 , 1145 , 7406 , 69 , 7 , 0 , 1 , 84.4 , 55.9 , 28.5 , 12.0 , 13.2 , 12.1 , 40.1 , 12.1 , 30.8 , 12.1 , 38.4 , 4 , 1.0680 , 42.1 , 25272 ,
2023-08-17 22:20:28 , 1935.0 , 1750.2 , 60.9 , 71.8 , 36 , 1148 , 36 , 1140 , 7399 , 100 , 6 , 0 , 2 , 89.0 , 60.8 , 28.3 , 12.0 , 14.0 , 12.1 , 41.5 , 12.1 , 33.2 , 12.1 , 40.5 , 4 , 1.0680 , 42.3 , 25296 ,
2023-08-17 22:20:29 , 1935.0 , 1750.2 , 61.6 , 72.5 , 36 , 1139 , 36 , 1147 , 7421 , 100 , 6 , 0 , 1 , 107.9 , 78.1 , 29.9 , 12.0 , 17.7 , 12.1 , 48.7 , 12.1 , 41.2 , 12.1 , 49.1 , 4 , 1.0680 , 41.9 , 25305 ,
2023-08-17 22:20:30 , 1935.0 , 1750.2 , 61.5 , 72.3 , 36 , 1146 , 36 , 1145 , 7408 , 100 , 8 , 0 , 1 , 88.3 , 60.2 , 28.0 , 12.0 , 13.9 , 12.1 , 41.1 , 12.1 , 33.0 , 12.1 , 40.1 , 4 , 1.0680 , 41.5 , 25314 ,
2023-08-17 22:20:32 , 1935.0 , 1750.2 , 61.1 , 72.0 , 36 , 1148 , 36 , 1141 , 7414 , 100 , 6 , 0 , 1 , 84.8 , 61.7 , 28.1 , 12.0 , 14.2 , 12.1 , 41.7 , 12.1 , 33.6 , 12.1 , 40.9 , 4 , 1.0680 , 41.8 , 25319 ,
2023-08-17 22:20:32 , 1935.0 , 1750.2 , 61.4 , 72.1 , 36 , 1144 , 36 , 1147 , 7416 , 100 , 7 , 0 , 1 , 105.0 , 75.6 , 29.5 , 12.0 , 16.8 , 12.1 , 47.6 , 12.1 , 39.1 , 12.1 , 47.2 , 4 , 1.0680 , 41.9 , 25315 ,
2023-08-17 22:20:33 , 1935.0 , 1750.2 , 61.7 , 72.7 , 36 , 1147 , 36 , 1147 , 7410 , 100 , 7 , 0 , 1 , 97.4 , 68.3 , 30.9 , 12.0 , 18.8 , 12.1 , 51.6 , 12.1 , 44.2 , 12.1 , 52.2 , 4 , 1.0680 , 42.6 , 25319 ,
2023-08-17 22:20:34 , 1935.0 , 1750.2 , 61.6 , 72.3 , 36 , 1147 , 36 , 1143 , 7401 , 100 , 7 , 0 , 1 , 95.6 , 66.9 , 28.7 , 12.0 , 15.6 , 12.1 , 43.7 , 12.1 , 35.9 , 12.1 , 43.4 , 4 , 1.0680 , 43.3 , 25329 ,
2023-08-17 22:20:35 , 1935.0 , 1750.2 , 60.8 , 71.7 , 36 , 1142 , 36 , 1144 , 7398 , 100 , 1 , 0 , 2 , 93.6 , 65.0 , 28.7 , 12.0 , 15.6 , 12.1 , 44.8 , 12.1 , 37.0 , 12.1 , 44.4 , 4 , 1.0680 , 43.6 , 25345 ,
2023-08-17 22:20:36 , 1935.0 , 1750.2 , 61.7 , 72.5 , 36 , 1146 , 36 , 1145 , 7346 , 100 , 9 , 0 , 2 , 109.2 , 79.0 , 30.2 , 12.0 , 15.4 , 12.1 , 44.5 , 12.1 , 36.6 , 12.1 , 44.0 , 4 , 1.0680 , 43.8 , 25355 ,
2023-08-17 22:20:37 , 1935.0 , 1750.2 , 61.8 , 72.8 , 36 , 1145 , 36 , 1143 , 7337 , 100 , 12 , 0 , 3 , 111.5 , 67.3 , 28.2 , 12.0 , 15.3 , 12.1 , 43.8 , 12.1 , 36.1 , 12.1 , 43.4 , 4 , 1.0680 , 44.4 , 25368 ,
2023-08-17 22:20:38 , 1935.0 , 1750.2 , 61.7 , 72.5 , 36 , 1147 , 36 , 1144 , 7292 , 100 , 7 , 0 , 1 , 87.1 , 71.1 , 28.2 , 12.0 , 16.2 , 12.2 , 44.8 , 12.1 , 38.0 , 12.1 , 45.1 , 4 , 1.0680 , 45.0 , 25414 ,
2023-08-17 22:20:40 , 1935.0 , 1750.2 , 60.8 , 72.1 , 36 , 1148 , 36 , 1147 , 7296 , 100 , 1 , 0 , 2 , 82.4 , 52.6 , 27.1 , 12.1 , 12.1 , 12.1 , 38.6 , 12.1 , 30.4 , 12.1 , 37.4 , 4 , 1.0680 , 45.3 , 25436 ,
2023-08-17 22:20:41 , 1935.0 , 1750.2 , 60.3 , 71.2 , 36 , 1145 , 36 , 1147 , 7317 , 100 , 1 , 0 , 2 , 82.2 , 55.1 , 27.1 , 12.1 , 12.8 , 12.1 , 38.5 , 12.1 , 29.2 , 12.1 , 35.6 , 4 , 1.0680 , 45.4 , 25491 ,
2023-08-17 22:20:42 , 1935.0 , 1750.2 , 59.9 , 70.8 , 36 , 1140 , 36 , 1139 , 7347 , 100 , 1 , 0 , 3 , 82.3 , 55.6 , 27.1 , 12.1 , 12.8 , 12.1 , 38.7 , 12.1 , 30.5 , 12.1 , 37.5 , 4 , 1.0680 , 45.4 , 25497 ,
2023-08-17 22:20:42 , 1935.0 , 1750.2 , 60.0 , 70.8 , 36 , 1143 , 36 , 1144 , 7336 , 100 , 1 , 0 , 1 , 78.0 , 50.6 , 27.4 , 12.1 , 12.0 , 12.1 , 37.1 , 12.1 , 28.5 , 12.1 , 35.5 , 4 , 1.0680 , 45.5 , 25382 ,
2023-08-17 22:20:44 , 1935.0 , 1750.2 , 59.8 , 70.7 , 36 , 1148 , 36 , 1142 , 7344 , 100 , 1 , 0 , 1 , 83.8 , 56.2 , 27.6 , 12.1 , 13.3 , 12.3 , 39.1 , 12.1 , 31.0 , 12.1 , 38.1 , 4 , 1.0680 , 45.4 , 25456 ,
2023-08-17 22:20:45 , 1935.0 , 1750.2 , 59.7 , 70.7 , 36 , 1136 , 36 , 1146 , 7351 , 100 , 1 , 0 , 2 , 80.2 , 53.0 , 27.3 , 12.1 , 12.5 , 12.1 , 37.9 , 12.1 , 29.5 , 12.1 , 36.5 , 4 , 1.0680 , 45.4 , 25455 ,
2023-08-17 22:20:46 , 1935.0 , 1750.2 , 59.8 , 70.8 , 36 , 1142 , 36 , 1138 , 7356 , 100 , 1 , 0 , 2 , 81.7 , 54.5 , 27.2 , 12.1 , 12.8 , 12.1 , 38.4 , 12.1 , 28.6 , 12.1 , 35.3 , 4 , 1.0680 , 45.3 , 25333 ,
2023-08-17 22:20:47 , 1935.0 , 1750.2 , 59.4 , 70.5 , 36 , 1143 , 36 , 1139 , 7363 , 100 , 1 , 0 , 2 , 81.1 , 54.2 , 26.9 , 12.1 , 12.2 , - , - , - , - , - , 35.4 , 0 , 0.0000 , 45.3 , 25347 ,
2023-08-17 22:20:48 , 1935.0 , 1750.2 , 59.3 , 70.3 , 36 , 1138 , 36 , 1142 , 7370 , 100 , 1 , 0 , 1 , 77.4 , 50.2 , 27.2 , 12.1 , 11.9 , 12.1 , 36.9 , 12.1 , 28.3 , 12.1 , 35.2 , 4 , 1.0680 , 45.3 , 25350 ,
2023-08-17 22:20:49 , 1935.0 , 1750.2 , 59.5 , 70.4 , 36 , 1136 , 36 , 1141 , 7396 , 100 , 1 , 0 , 3 , 77.8 , 50.8 , 27.1 , 12.1 , 12.0 , 12.1 , 36.9 , 12.1 , 28.5 , 12.1 , 35.4 , 4 , 1.0680 , 44.5 , 25342 ,
2023-08-17 22:20:50 , 1935.0 , 1750.2 , 59.6 , 70.6 , 36 , 1139 , 36 , 1134 , 7414 , 100 , 1 , 0 , 2 , 80.9 , 54.0 , 27.0 , 12.1 , 12.4 , 12.1 , 36.9 , 12.1 , 30.1 , 12.1 , 37.0 , 4 , 1.0680 , 43.9 , 25350 ,
2023-08-17 22:20:51 , 1935.0 , 1750.2 , 59.2 , 70.3 , 36 , 1138 , 36 , 1139 , 7417 , 100 , 1 , 0 , 1 , 82.7 , 55.8 , 26.9 , 12.1 , 13.6 , 12.1 , 37.1 , 12.1 , 29.1 , 12.1 , 38.0 , 4 , 1.0680 , 43.4 , 25384 ,
2023-08-17 22:20:54 , 1950.0 , 1750.2 , 59.3 , 70.3 , 36 , 1135 , 36 , 1134 , 7419 , 100 , 1 , 0 , 1 , 83.4 , 56.0 , 27.4 , 12.1 , 13.1 , 12.1 , 39.0 , 12.1 , 31.0 , 12.1 , 36.0 , 4 , 1.0750 , 42.4 , 25391 ,
2023-08-17 22:20:55 , 1950.0 , 1750.2 , 59.4 , 70.3 , 36 , 1135 , 35 , 1135 , 7423 , 100 , 1 , 0 , 2 , 81.6 , 54.4 , 27.2 , 12.1 , 12.7 , 12.1 , 38.4 , 12.1 , 30.1 , 12.1 , 37.1 , 4 , 1.0750 , 41.8 , 25393 ,
2023-08-17 22:20:56 , 1950.0 , 1750.2 , 59.1 , 70.2 , 35 , 1134 , 35 , 1131 , 7431 , 100 , 1 , 0 , 2 , 85.8 , 58.5 , 27.3 , 12.0 , 13.5 , 12.1 , 39.9 , 12.1 , 32.0 , 12.1 , 39.0 , 4 , 1.0750 , 41.5 , 25401 ,
2023-08-17 22:20:58 , 1950.0 , 1750.2 , 59.0 , 69.9 , 35 , 1138 , 35 , 1131 , 7430 , 100 , 1 , 0 , 2 , 81.5 , 54.5 , 27.0 , 12.1 , 12.7 , 12.1 , 38.3 , 12.1 , 30.2 , 12.1 , 37.1 , 4 , 1.0750 , 41.3 , 25442 ,
2023-08-17 22:21:00 , 1950.0 , 1750.2 , 58.9 , 69.9 , 35 , 1133 , 35 , 1132 , 7411 , 100 , 1 , 0 , 2 , 86.9 , 59.5 , 27.4 , 12.1 , 12.2 , 12.1 , 37.2 , 12.1 , 30.3 , 12.1 , 35.4 , 4 , 1.0750 , 40.5 , 25430 ,
2023-08-17 22:21:01 , 1950.0 , 1750.2 , 58.9 , 70.0 , 35 , 1135 , 35 , 1131 , 7407 , 100 , 2 , 0 , 2 , 86.9 , 59.1 , 27.7 , 12.0 , 13.7 , 12.1 , 40.4 , 12.1 , 32.4 , 12.1 , 39.5 , 4 , 1.0750 , 40.6 , 25442 ,
2023-08-17 22:21:02 , 1950.0 , 1750.2 , 59.7 , 70.4 , 35 , 1132 , 35 , 1129 , 7390 , 100 , 6 , 0 , 3 , 87.7 , 59.7 , 28.0 , 12.0 , 13.8 , 12.1 , 40.8 , 12.1 , 32.7 , 12.1 , 39.6 , 4 , 1.0750 , 40.6 , 25439 ,
2023-08-17 22:21:03 , 1950.0 , 1750.2 , 59.3 , 70.3 , 35 , 1130 , 35 , 1128 , 7403 , 100 , 1 , 0 , 2 , 87.6 , 59.9 , 27.7 , 12.0 , 15.7 , 12.1 , 44.7 , 12.1 , 37.1 , 12.1 , 44.4 , 4 , 1.0750 , 40.5 , 25453 ,
2023-08-17 22:21:03 , 1950.0 , 1750.2 , 59.3 , 70.3 , 35 , 1132 , 35 , 1131 , 7380 , 100 , 3 , 0 , 2 , 83.4 , 55.8 , 27.6 , 12.0 , 13.1 , 12.2 , 39.2 , 12.1 , 30.8 , 12.1 , 37.9 , 4 , 1.0750 , 40.6 , 25449 ,
2023-08-17 22:21:05 , 1950.0 , 1750.2 , 59.0 , 69.9 , 35 , 1130 , 35 , 1129 , 7384 , 100 , 1 , 0 , 1 , 80.4 , 53.5 , 26.9 , 12.1 , 12.5 , 12.0 , 37.9 , 12.1 , 29.7 , 12.1 , 36.6 , 4 , 1.0750 , 40.6 , 25465 ,
2023-08-17 22:21:07 , 1950.0 , 1750.2 , 58.9 , 69.9 , 35 , 1130 , 35 , 1131 , 7381 , 100 , 1 , 0 , 2 , 77.3 , 51.0 , 26.8 , 12.1 , 12.0 , 12.1 , 37.6 , 12.1 , 29.4 , 12.1 , 36.2 , 4 , 1.0750 , 40.4 , 25464 ,
2023-08-17 22:21:09 , 1950.0 , 1750.2 , 58.7 , 69.7 , 35 , 1134 , 35 , 1131 , 7382 , 100 , 1 , 0 , 5 , 88.2 , 59.7 , 27.0 , 12.1 , 11.9 , 12.1 , 36.3 , 12.1 , 30.7 , 12.1 , 37.4 , 4 , 1.0750 , 40.0 , 25459 ,
2023-08-17 22:21:09 , 1950.0 , 1750.2 , 58.5 , 69.6 , 35 , 1135 , 35 , 1131 , 7400 , 100 , 1 , 0 , 1 , 80.4 , 53.3 , 27.1 , 12.1 , 12.5 , 12.1 , 37.9 , 12.1 , 29.6 , 12.1 , 36.5 , 4 , 1.0750 , 40.0 , 25467 ,
2023-08-17 22:21:11 , 1950.0 , 1750.2 , 58.5 , 69.6 , 35 , 1122 , 35 , 1131 , 7398 , 100 , 1 , 0 , 2 , 85.5 , 58.3 , 27.2 , 12.0 , 13.3 , 12.1 , 39.8 , 12.1 , 32.0 , 12.1 , 38.8 , 4 , 1.0750 , 40.0 , 25468 ,
2023-08-17 22:21:12 , 1950.0 , 1750.2 , 58.4 , 69.6 , 35 , 1114 , 35 , 1124 , 7408 , 100 , 1 , 0 , 2 , 77.7 , 50.7 , 27.0 , 12.1 , 12.0 , 12.1 , 36.9 , 12.1 , 28.5 , 12.1 , 35.3 , 4 , 1.0750 , 39.8 , 25464 ,
2023-08-17 22:21:13 , 1950.0 , 1750.2 , 58.4 , 69.5 , 35 , 1112 , 35 , 1111 , 7416 , 100 , 1 , 0 , 2 , 77.7 , 50.7 , 27.0 , 12.1 , 12.0 , 12.1 , 36.9 , 12.1 , 28.5 , 12.1 , 35.3 , 4 , 1.0750 , 39.9 , 25464 ,
2023-08-17 22:21:13 , 1950.0 , 1750.2 , 58.2 , 69.3 , 35 , 1114 , 35 , 1107 , 7416 , 100 , 1 , 0 , 2 , 77.8 , 50.9 , 26.9 , 12.1 , 12.0 , 12.1 , 36.9 , 12.1 , 28.6 , 12.1 , 35.4 , 4 , 1.0750 , 39.6 , 25468 ,
2023-08-17 22:21:14 , 1950.0 , 1750.2 , 58.3 , 69.4 , 35 , 1114 , 35 , 1112 , 7419 , 100 , 1 , 0 , 2 , 82.4 , 55.5 , 26.9 , 12.0 , 12.7 , 12.1 , 38.7 , 12.1 , 30.6 , 12.1 , 37.4 , 4 , 1.0750 , 39.8 , 25464 ,
2023-08-17 22:21:16 , 1950.0 , 1750.2 , 58.3 , 69.4 , 35 , 1112 , 35 , 1115 , 7428 , 100 , 1 , 0 , 2 , 79.8 , 52.7 , 27.1 , 12.1 , 12.5 , 12.2 , 37.6 , 12.1 , 29.3 , 12.1 , 36.3 , 4 , 1.0750 , 39.5 , 25464 ,
2023-08-17 22:21:18 , 1950.0 , 1750.2 , 58.2 , 69.1 , 35 , 1114 , 35 , 1109 , 7428 , 100 , 1 , 0 , 6 , - , - , - , - , - , - , - , - , - , - , 36.9 , 4 , 1.0750 , 39.5 , 25480 ,
2023-08-17 22:21:18 , 1950.0 , 1750.2 , 58.3 , 69.3 , 34 , 1112 , 34 , 1108 , 7447 , 100 , 1 , 0 , 2 , 79.6 , 50.8 , 27.0 , 12.1 , 12.2 , 12.1 , 37.5 , 12.1 , 29.0 , 12.1 , 35.9 , 4 , 1.0750 , 39.5 , 25480 ,
2023-08-17 22:21:18 , 1950.0 , 1750.2 , 58.0 , 69.3 , 34 , 1110 , 34 , 1107 , 7451 , 100 , 1 , 0 , 2 , 77.5 , 50.5 , 27.0 , 12.1 , 12.0 , 12.1 , 36.8 , 12.1 , 28.3 , 12.1 , 35.2 , 4 , 1.0750 , 39.6 , 25486 ,
2023-08-17 22:21:19 , 1950.0 , 1750.2 , 58.2 , 69.3 , 34 , 1108 , 34 , 1105 , 7456 , 100 , 1 , 0 , 2 , 79.2 , 52.2 , 27.0 , 12.1 , 12.3 , 12.1 , 37.4 , 12.1 , 29.1 , 12.1 , 36.0 , 4 , 1.0750 , 39.5 , 25487 ,
2023-08-17 22:21:21 , 1950.0 , 1750.2 , 58.0 , 69.2 , 34 , 1108 , 34 , 1105 , 7456 , 100 , 1 , 0 , 1 , 84.5 , 57.3 , 27.2 , 12.1 , 13.2 , 12.1 , 39.4 , 12.1 , 31.6 , 12.1 , 38.4 , 4 , 1.0750 , 39.5 , 25498 ,
2023-08-17 22:21:22 , 1950.0 , 1750.2 , 58.1 , 69.3 , 34 , 1108 , 34 , 1105 , 7460 , 100 , 1 , 0 , 2 , 80.7 , 53.9 , 26.8 , 12.1 , 12.5 , 12.1 , 36.8 , 12.1 , 29.7 , 12.1 , 36.5 , 4 , 1.0750 , 39.4 , 25503 ,
2023-08-17 22:21:23 , 1950.0 , 1750.2 , 57.8 , 68.9 , 34 , 1106 , 34 , 1105 , 7464 , 100 , 1 , 0 , 3 , 81.3 , 54.6 , 26.6 , 12.1 , 12.6 , 12.2 , 38.2 , 12.1 , 32.3 , 12.1 , 39.5 , 4 , 1.0750 , 39.6 , 25518 ,
2023-08-17 22:21:23 , 1950.0 , 1750.2 , 58.1 , 69.1 , 34 , 1106 , 34 , 1103 , 7442 , 100 , 1 , 0 , 1 , 86.2 , 58.7 , 27.4 , 12.0 , 13.5 , 12.1 , 40.2 , 12.1 , 32.2 , 12.1 , 39.2 , 4 , 1.0750 , 40.1 , 25480 ,
2023-08-17 22:21:24 , 1950.0 , 1750.2 , 59.8 , 70.3 , 34 , 1105 , 34 , 1103 , 7388 , 100 , 12 , 0 , 3 , 116.3 , 67.4 , 28.9 , 12.0 , 15.3 , 12.1 , 44.4 , 12.1 , 36.2 , 12.1 , 43.8 , 4 , 1.0750 , 40.3 , 25493 ,
2023-08-17 22:21:25 , 1950.0 , 1750.2 , 59.1 , 70.1 , 34 , 1104 , 34 , 1103 , 7360 , 100 , 7 , 0 , 1 , 95.2 , 66.4 , 28.8 , 12.0 , 15.2 , 12.1 , 43.9 , 12.1 , 35.9 , 12.1 , 43.3 , 4 , 1.0750 , 40.6 , 25486 ,
2023-08-17 22:21:26 , 1950.0 , 1750.2 , 59.5 , 70.2 , 34 , 1106 , 34 , 1102 , 7322 , 100 , 8 , 0 , 1 , 95.7 , 66.9 , 28.8 , 12.0 , 15.2 , 12.1 , 44.1 , 12.1 , 36.1 , 12.1 , 43.5 , 4 , 1.0750 , 40.6 , 25488 ,
2023-08-17 22:21:27 , 1950.0 , 1750.2 , 59.3 , 70.3 , 34 , 1108 , 34 , 1104 , 7296 , 100 , 7 , 0 , 1 , 96.8 , 69.0 , 28.3 , 12.0 , 15.4 , 12.1 , 44.7 , 12.1 , 36.9 , 12.1 , 44.2 , 4 , 1.0750 , 40.8 , 25500 ,
2023-08-17 22:21:29 , 1950.0 , 1750.2 , 58.2 , 69.3 , 34 , 1107 , 34 , 1105 , 6886 , 100 , 1 , 0 , 3 , 81.4 , 54.8 , 26.8 , 12.1 , 12.4 , 12.1 , 37.2 , 12.1 , 28.5 , 12.1 , 35.3 , 4 , 1.0750 , 40.5 , 25475 ,
2023-08-17 22:21:29 , 1950.0 , 1750.2 , 58.0 , 69.2 , 34 , 1108 , 34 , 1105 , 6966 , 100 , 1 , 0 , 2 , 77.3 , 50.2 , 27.2 , 12.1 , 12.0 , 12.1 , 36.7 , 12.1 , 28.3 , 12.1 , 35.2 , 4 , 1.0750 , 40.5 , 25427 ,
2023-08-17 22:21:30 , 1950.0 , 1750.2 , 59.6 , 70.5 , 34 , 1105 , 34 , 1106 , 7058 , 26 , 9 , 0 , 0 , 112.5 , 81.5 , 31.0 , 12.0 , 18.5 , 12.1 , 50.6 , 12.1 , 43.0 , 12.1 , 51.2 , 4 , 1.0750 , 40.6 , 25309 ,
2023-08-17 22:21:31 , 1950.0 , 1750.2 , 59.2 , 70.1 , 34 , 1106 , 34 , 1105 , 7248 , 23 , 9 , 0 , 1 , 91.3 , 61.7 , 29.6 , 12.0 , 14.5 , 12.1 , 42.8 , 12.1 , 33.7 , 12.1 , 41.5 , 4 , 1.0750 , 41.8 , 25398 ,
2023-08-17 22:21:32 , 1455.0 , 1750.2 , 56.7 , 68.5 , 34 , 1106 , 34 , 1103 , 6170 , 22 , 7 , 0 , 0 , 60.2 , 31.3 , 28.9 , 12.1 , 7.3 , 12.1 , 34.5 , 12.1 , 18.1 , 12.1 , 27.4 , 16 , 0.7930 , 42.4 , 23854 ,
2023-08-17 22:21:33 , 1230.0 , 1250.2 , 55.4 , 67.2 , 34 , 1101 , 34 , 1104 , 5058 , 30 , 11 , 0 , 0 , 49.5 , 21.8 , 27.7 , 12.1 , 5.5 , 12.1 , 30.3 , 12.1 , 13.4 , 12.1 , 22.5 , 16 , 0.7120 , 42.5 , 23844 ,
2023-08-17 22:21:34 , 1095.0 , 1250.2 , 54.8 , 66.8 , 34 , 1092 , 34 , 1107 , 3890 , 34 , 11 , 0 , 0 , 48.7 , 20.7 , 28.0 , 12.1 , 4.9 , 12.1 , 30.6 , 12.1 , 12.9 , 12.1 , 22.1 , 16 , 0.6870 , 42.4 , 23686 ,
2023-08-17 22:21:35 , 1005.0 , 1250.2 , 54.8 , 66.9 , 34 , 1087 , 34 , 1094 , 1993 , 33 , 11 , 0 , 0 , 46.9 , 18.9 , 27.9 , 12.1 , 4.6 , 12.1 , 29.9 , 12.1 , 12.1 , 12.1 , 21.3 , 16 , 0.6870 , 42.3 , 19246 ,
2023-08-17 22:21:36 , 1755.0 , 1750.2 , 56.1 , 67.7 , 34 , 1083 , 34 , 1086 , 2035 , 22 , 8 , 0 , 1 , 72.1 , 42.5 , 29.5 , 12.0 , 10.1 , 12.1 , 37.4 , 12.1 , 24.2 , 12.1 , 32.8 , 16 , 0.9250 , 42.5 , 15705 ,
2023-08-17 22:21:37 , 1755.0 , 1750.2 , 56.1 , 67.8 , 33 , 1082 , 33 , 1083 , 2043 , 24 , 9 , 0 , 0 , 72.3 , 42.9 , 29.5 , 12.0 , 10.2 , 12.1 , 37.5 , 12.1 , 24.3 , 12.1 , 32.9 , 16 , 0.9250 , 43.5 , 15699 ,
2023-08-17 22:21:38 , 1755.0 , 1750.2 , 56.3 , 67.9 , 33 , 1081 , 33 , 1082 , 2049 , 24 , 9 , 0 , 0 , 75.8 , 45.7 , 30.0 , 12.0 , 10.7 , 12.1 , 39.0 , 12.1 , 25.7 , 12.1 , 34.4 , 16 , 0.9250 , 44.8 , 15867 ,
2023-08-17 22:21:39 , 1200.0 , 1250.2 , 56.5 , 68.0 , 33 , 1080 , 33 , 1080 , 2050 , 24 , 9 , 0 , 0 , 72.0 , 42.4 , 29.6 , 12.0 , 10.1 , 12.1 , 37.5 , 12.1 , 24.1 , 12.1 , 32.7 , 16 , 0.6930 , 44.9 , 16016 ,
2023-08-17 22:21:40 , 1140.0 , 1250.2 , 54.3 , 66.3 , 33 , 1080 , 33 , 1081 , 2049 , 39 , 13 , 0 , 0 , 48.7 , 20.5 , 28.2 , 12.1 , 5.0 , 12.1 , 30.7 , 12.1 , 12.8 , 12.1 , 22.2 , 16 , 0.6870 , 44.9 , 15729 ,
2023-08-17 22:21:41 , 1065.0 , 1250.2 , 54.3 , 66.2 , 33 , 1082 , 33 , 1081 , 2036 , 35 , 13 , 0 , 0 , 47.2 , 19.3 , 28.0 , 12.1 , 4.7 , 12.1 , 29.9 , 12.1 , 12.3 , 12.1 , 21.5 , 16 , 0.6930 , 45.5 , 15830 ,
2023-08-17 22:21:42 , 1005.0 , 1250.2 , 53.8 , 65.8 , 33 , 1082 , 33 , 1081 , 2035 , 35 , 12 , 0 , 0 , 47.2 , 19.1 , 28.1 , 12.1 , 4.7 , 12.1 , 30.0 , 12.1 , 12.2 , 12.1 , 21.4 , 16 , 0.6930 , 45.6 , 16098 ,
2023-08-17 22:21:43 , 960.0 , 1250.2 , 53.7 , 65.8 , 33 , 1082 , 33 , 1079 , 2029 , 39 , 13 , 0 , 1 , 48.2 , 19.7 , 28.5 , 12.1 , 4.8 , 12.1 , 30.7 , 12.1 , 12.4 , 12.1 , 21.9 , 16 , 0.6930 , 45.0 , 16099 ,
2023-08-17 22:21:44 , 1050.0 , 1250.2 , 53.7 , 65.7 , 33 , 1082 , 33 , 1080 , 2015 , 37 , 12 , 0 , 0 , 47.8 , 19.4 , 28.4 , 12.1 , 4.8 , 12.1 , 30.1 , 12.1 , 12.5 , 12.1 , 21.7 , 16 , 0.6930 , 45.6 , 16130 ,
2023-08-17 22:21:45 , 1095.0 , 1250.2 , 53.5 , 65.4 , 33 , 1083 , 33 , 1081 , 2039 , 36 , 13 , 0 , 1 , 48.0 , 19.7 , 28.3 , 12.1 , 4.8 , 12.1 , 30.3 , 12.1 , 12.6 , 12.1 , 21.8 , 16 , 0.6930 , 46.1 , 16179 ,
2023-08-17 22:21:46 , 1110.0 , 1250.2 , 53.5 , 65.4 , 32 , 1083 , 32 , 1080 , 2040 , 34 , 12 , 0 , 0 , 47.6 , 19.7 , 27.9 , 12.1 , 4.7 , 12.1 , 30.0 , 12.1 , 12.5 , 12.1 , 21.6 , 16 , 0.6930 , 46.0 , 16054 ,
2023-08-17 22:21:47 , 1080.0 , 1250.2 , 53.4 , 65.4 , 32 , 1073 , 32 , 1072 , 2041 , 38 , 15 , 0 , 0 , 49.2 , 20.6 , 28.6 , 12.1 , 5.0 , 12.1 , 31.0 , 12.1 , 12.9 , 12.1 , 22.4 , 16 , 0.6930 , 45.8 , 16066 ,
2023-08-17 22:21:48 , 1020.0 , 1250.2 , 53.2 , 65.5 , 32 , 1064 , 32 , 1063 , 2018 , 39 , 13 , 0 , 0 , 49.5 , 20.9 , 28.7 , 12.1 , 5.1 , 12.1 , 31.1 , 12.1 , 13.0 , 12.1 , 22.5 , 16 , 0.6930 , 45.5 , 16081 ,
2023-08-17 22:21:49 , 990.0 , 1250.2 , 53.3 , 65.3 , 32 , 1060 , 32 , 1056 , 2022 , 40 , 13 , 0 , 1 , 50.1 , 21.1 , 29.0 , 12.1 , 5.2 , 12.1 , 31.5 , 12.1 , 13.1 , 12.1 , 22.8 , 16 , 0.6930 , 45.1 , 16112 ,
2023-08-17 22:21:50 , 1065.0 , 1250.2 , 53.1 , 65.1 , 32 , 1058 , 32 , 1054 , 2023 , 39 , 13 , 0 , 0 , 47.0 , 19.1 , 27.9 , 12.1 , 4.6 , 12.1 , 29.9 , 12.1 , 12.2 , 12.1 , 21.4 , 16 , 0.6930 , 44.8 , 16128 ,
2023-08-17 22:21:51 , 1065.0 , 1250.2 , 53.1 , 65.3 , 32 , 1056 , 32 , 1052 , 2009 , 35 , 12 , 0 , 1 , 47.1 , 19.2 , 27.8 , 12.1 , 4.6 , 12.1 , 29.9 , 12.1 , 12.2 , 12.1 , 21.4 , 16 , 0.6930 , 44.5 , 16134 ,
2023-08-17 22:21:52 , 990.0 , 1250.2 , 52.8 , 64.8 , 31 , 1055 , 31 , 1051 , 2033 , 38 , 13 , 0 , 0 , 47.8 , 19.4 , 28.4 , 12.1 , 4.7 , 12.1 , 30.4 , 12.1 , 12.4 , 12.1 , 21.7 , 16 , 0.6930 , 44.3 , 16140 ,
2023-08-17 22:21:53 , 960.0 , 1250.2 , 52.9 , 64.9 , 31 , 1043 , 31 , 1046 , 1973 , 40 , 13 , 0 , 0 , 47.4 , 19.3 , 28.0 , 12.1 , 4.5 , 12.1 , 30.3 , 12.1 , 12.2 , 12.1 , 21.5 , 16 , 0.6930 , 44.3 , 16155 ,
2023-08-17 22:21:54 , 1020.0 , 1250.2 , 52.7 , 64.8 , 31 , 1034 , 31 , 1035 , 1973 , 37 , 13 , 0 , 0 , 47.0 , 19.3 , 27.7 , 12.1 , 4.5 , 12.1 , 30.0 , 12.1 , 12.2 , 12.1 , 21.4 , 16 , 0.6930 , 44.4 , 16165 ,
2023-08-17 22:21:55 , 1035.0 , 1250.2 , 52.7 , 64.7 , 31 , 1030 , 31 , 1030 , 2024 , 40 , 13 , 0 , 0 , 48.9 , 20.6 , 28.4 , 12.1 , 4.8 , 12.1 , 30.9 , 12.1 , 12.9 , 12.1 , 22.2 , 16 , 0.6930 , 44.4 , 16183 ,
2023-08-17 22:21:56 , 1035.0 , 1250.2 , 52.6 , 64.6 , 31 , 1028 , 31 , 1026 , 2024 , 37 , 13 , 0 , 0 , 47.8 , 19.7 , 28.1 , 12.1 , 4.7 , 12.1 , 30.4 , 12.1 , 12.5 , 12.1 , 21.7 , 16 , 0.6930 , 44.1 , 16192 ,
2023-08-17 22:21:57 , 1020.0 , 1250.2 , 52.4 , 64.5 , 30 , 1026 , 30 , 1025 , 2024 , 41 , 13 , 0 , 1 , 49.5 , 20.9 , 28.7 , 12.1 , 4.9 , 12.1 , 31.3 , 12.1 , 13.0 , 12.1 , 22.5 , 16 , 0.6930 , 43.9 , 16204 ,
2023-08-17 22:21:58 , 1020.0 , 1250.2 , 52.5 , 64.7 , 30 , 1025 , 30 , 1023 , 1945 , 38 , 13 , 0 , 1 , 49.0 , 20.7 , 28.3 , 12.1 , 4.9 , 12.1 , 30.9 , 12.1 , 12.9 , 12.1 , 22.3 , 16 , 0.6930 , 43.6 , 16215 ,
2023-08-17 22:21:59 , 1110.0 , 1250.2 , 52.3 , 64.2 , 30 , 1023 , 30 , 1023 , 1969 , 38 , 13 , 0 , 0 , 47.6 , 19.7 , 27.9 , 12.1 , 4.6 , 12.1 , 30.3 , 12.1 , 12.4 , 12.1 , 21.6 , 16 , 0.6930 , 43.3 , 16235 ,
2023-08-17 22:22:00 , 1125.0 , 1250.2 , 52.1 , 64.2 , 30 , 1010 , 30 , 1009 , 2033 , 40 , 14 , 0 , 0 , 48.0 , 20.1 , 27.8 , 12.1 , 4.6 , 12.1 , 30.5 , 12.1 , 12.6 , 12.1 , 21.8 , 16 , 0.6930 , 43.1 , 16254 ,
2023-08-17 22:22:01 , 1140.0 , 1250.2 , 52.3 , 64.4 , 30 , 1003 , 30 , 1002 , 2072 , 40 , 14 , 0 , 1 , 48.3 , 20.3 , 28.1 , 12.1 , 4.7 , 12.1 , 30.6 , 12.1 , 12.6 , 12.1 , 22.0 , 16 , 0.6930 , 44.1 , 16536 ,
2023-08-17 22:22:02 , 1050.0 , 1250.2 , 52.0 , 63.9 , 30 , 1000 , 30 , 998 , 2087 , 32 , 12 , 0 , 1 , 46.6 , 19.3 , 27.3 , 12.1 , 4.4 , 12.1 , 29.8 , 12.1 , 12.1 , 12.1 , 21.2 , 16 , 0.6930 , 45.1 , 16658 ,
2023-08-17 22:22:03 , 1020.0 , 1250.2 , 52.1 , 64.1 , 30 , 999 , 30 , 996 , 2153 , 39 , 13 , 0 , 1 , 47.3 , 19.4 , 27.9 , 12.1 , 4.5 , 12.1 , 30.3 , 12.1 , 12.2 , 12.1 , 21.5 , 16 , 0.6930 , 46.1 , 16908 ,
2023-08-17 22:22:04 , 990.0 , 1250.2 , 52.0 , 64.0 , 30 , 1000 , 30 , 996 , 2180 , 38 , 13 , 0 , 0 , 49.4 , 21.0 , 28.4 , 12.1 , 4.9 , 12.1 , 31.3 , 12.1 , 13.0 , 12.1 , 22.5 , 16 , 0.6930 , 46.5 , 16802 ,
2023-08-17 22:22:05 , 1110.0 , 1250.2 , 51.8 , 63.8 , 30 , 996 , 30 , 994 , 2232 , 43 , 14 , 0 , 0 , 47.9 , 19.9 , 28.0 , 12.1 , 4.6 , 12.1 , 30.6 , 12.1 , 12.4 , 12.1 , 21.8 , 16 , 0.6930 , 46.8 , 16848 ,
2023-08-17 22:22:06 , 1755.0 , 1750.2 , 52.8 , 64.6 , 30 , 999 , 30 , 993 , 2244 , 34 , 12 , 0 , 0 , 56.8 , 28.5 , 28.4 , 12.1 , 6.6 , 12.1 , 33.1 , 12.1 , 16.8 , 12.1 , 25.8 , 16 , 0.9180 , 46.5 , 16810 ,
2023-08-17 22:22:07 , 1755.0 , 1750.2 , 53.4 , 65.2 , 30 , 998 , 30 , 998 , 2192 , 25 , 9 , 0 , 0 , 69.9 , 40.7 , 29.2 , 12.0 , 9.4 , 12.1 , 37.0 , 12.1 , 23.2 , 12.1 , 31.8 , 16 , 0.9180 , 46.1 , 16813 ,
2023-08-17 22:22:08 , 1755.0 , 1750.2 , 53.5 , 65.4 , 30 , 997 , 30 , 1007 , 2193 , 25 , 9 , 0 , 1 , 68.7 , 39.8 , 28.8 , 12.0 , 9.3 , 12.1 , 36.4 , 12.1 , 22.7 , 12.1 , 31.2 , 16 , 0.9180 , 46.0 , 16821 ,
2023-08-17 22:22:09 , 1290.0 , 1250.2 , 53.9 , 65.4 , 30 , 996 , 30 , 999 , 2169 , 25 , 9 , 0 , 0 , 70.5 , 41.2 , 29.4 , 12.0 , 9.8 , 12.1 , 37.0 , 12.1 , 23.4 , 12.1 , 32.1 , 16 , 0.7310 , 45.6 , 16814 ,
2023-08-17 22:22:10 , 1215.0 , 1250.2 , 52.0 , 64.0 , 30 , 998 , 30 , 997 , 2319 , 37 , 13 , 0 , 0 , 48.7 , 21.2 , 27.5 , 12.1 , 5.0 , 12.1 , 30.3 , 12.1 , 13.0 , 12.1 , 22.1 , 16 , 0.7120 , 45.3 , 16820 ,
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard?
As for your drivers being reinstalled, can you walk us through how you removed the GPU drivers?
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Ah ok, thanks.
CAS: Corsair 4000D Series Mid-Tower Black Gaming Case (OEM - no fans included) [-3]
CPU: AMD Ryzen 7 5800X - 8-Core 3.80GHz, 4.7GHz Turbo - 32MB L3 Cache Processor, Pro OC
FAN: Corsair H150 PRO XT
MEMORY: 32GB (4x8GB) DDR4/3200mhz Dual Channel Memory [+73] (HyperX Fury RGB w/Heat Spreader) ---(this is whats on my order, but task manager reports 2400mhz - an xmp thing? 🤷🏻‍♂️)
MONITOR: MSI MAG272QR
MOTHERBOARD: MSI MPG X570 Gaming Edge WIFI: ATX w/ RGB, PCIe 4.0, USB 3.2, SATA3, 2x M.2 [+74]
AMI BIOS 7C37vAK
OS: Windows 11 home 22h2 22621.2070
POWERSUPPLY: Corsair RM850x 850W 80+ Gold Modular Gaming Power Supply [+52]
GPU: MSI GeForce(R) RTX 3070 8GB - Ray Tracing Technology, DX12(R), VR Ready, HDMI, DP - 4 Monitor Support (Single Card)
Storage: 1TB (1x1TB) WD Blue SN550 M.2 NVMe PCIe SSD - 2400MB/s Read & 1950MB/s Write [+31]
The whole pc is new from feb 2021
For reinstalling drivers
Boot into safe mode > run Display Driver Uninstaller > reboot into safe mode >DL driver from https://www.nvidia.com/Download/index.aspx?lang=en-us
Doesn't really seem like there's a problem here with the video card until it hits 2023-08-17 22:13:11 and the usage plummets and you can see the VRAM not being utilized. It maintains the clockspeed, but when the temps drop so does the power consumption and memory controller usage.
This may sound weird, but have you tabbed out of the game and back in to see if that has any impact on the behavior?
I'm assuming you don't have your video card hooked up with a riser cable, but if you do plugging the card directly into the motherboard would be a good thing to try (if you can't do this try forcing PCIe 3.0 mode in the BIOS).
