Question Higher CPU temp when running Apex Legends ?
Sal1ty05
Commendable
May 2, 2021
34
When I play Apex Legends On Steam I get about 70c+ in game. No other game does this. I play mainly Competitive games so I always run low settings. I'm not sure why it goes that high.
I do have Gamemode/hags on. PBO is on.
My build
7950x3d
arctic freezer II 280mm
x670E Asrock Taichi
32gb neo trident 6000mhz
7000D corsair with 7 case fans
XFX 7900XTX AMD
SN850x m.2 ssd x3, 1Tb, 1Tb, and 2Tb
I mean that temp is not ideal, but its no where near concerning. It being a battle royale does mean it uses a fair amount of your CPU, but i dont know, your pc being a brand new one, i dont think a simple repaste on your CPU would solve it, maybe fan config? What fan config are you running?
If it means anything to you, my r5 3600 runs around 65C on Forza Horizon 5, cooled by a ROG RYUJIN 360mm rad, mounted on top of a CM H500P mesh case.
i got 7 case fans not including the cpu cooler fans so 4 exhaust and 3 intake. its the only game that makes my cpu run that hot.
