Higher fps with low resolution?
The higher the resolution the more demanding it is on the GPU. Depending on the graphics settings in the program being used will also affect the FPS you will see. In this case the GPU is just about maxed out in the example you gave so it seems to be the bottle neck in that particular program at 1920 x 1080 resolution.
