J javihere Reputable Mar 17, 2014 20 0 4,510 Apr 6, 2014 #1 Hi everyone, Someone can tell me which its the highest possible gpu for i3-4130 Thanks
rolli59 Titan Oct 27, 2007 47,801 284 130,890 Apr 6, 2014 #2 I would match it max with GTX770 or R9 280X although I think GTX760 would be the best balance. Upvote 1 Downvote
13thmonkey Titan Jan 10, 2006 24,790 350 75,790 Apr 6, 2014 #3 but strictly speaking any cpu will go with it. Upvote 0 Downvote
J javihere Reputable Mar 17, 2014 20 0 4,510 Apr 6, 2014 #4 so the r9 270 or the r9 270x need to work fine without bottleneck? Upvote 0 Downvote
dish_moose Splendid Jul 7, 2010 2,952 0 21,460 Apr 6, 2014 #5 Also depending if you want to play online multi player - that cpu will hold you back then - maybe a GTX 750 Ti? If you want to put in a quad core - 770 all the way. -Bruce Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,801 284 130,890 Apr 6, 2014 Solution #6 Yes they will be well balanced! Upvote 0 Downvote Solution
