Hello,i've been trying to solve this problem for over a month.First,i've noticed that in call of duty 1,where i had 333 fps, it felt like 30.Then i used Latencymon for test,i'll post the results.
My pc components(pretty low,but cmon its call of duty 1):
cpu:Intel Pentium Dual CPU E2140 1.60GHz,
RAM:2GB,
GPU:Nvidia GT220,
MB5LD2-X/1333,
HDD:Toshiba P300 1TB,
Windows 7 64-bit,
Things i've tried:
1.changed hdd,
2.clean instal of windows 7(i had 32bit now 64),
3.replaced thermal paste on both cpu and gpu,
4.pluging and unpluging almost every cable inside the pc,
5.uninstalling antivirus,
6.updated drivers via driver booster 6,
7.rolled back some drivers(display,network,and sound),
8.<<<<<nvlddmkm latency went down by disabling display driver,but there must be another way>>>>>
Things i haven't tried:
1.updating BIOS,
2.changing anything in BIOS,
I'm facing stuttering in every single game i try to play(cod 1,lol,cod2,gta vice city,minecraft)despite playing with the lowest possible graphic settings.Help me please .Check the results.
The following results are from testing the pc on idle:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:01:37 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: X-PC
OS version: Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
Hardware: ASUSTeK Computer INC., P5LD2-X/1333
CPU: GenuineIntel Intel(R) Pentium(R) Dual CPU E2140 @ 1.60GHz
Logical processors: 2
Processor groups: 1
RAM: 2047 MB total
CPU SPEED
Reported CPU speed: 160 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 4865.920
Average measured interrupt to process latency (µs): 5.101069
Highest measured interrupt to DPC latency (µs): 1111.040
Average measured interrupt to DPC latency (µs): 2.082739
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 120.60
Driver with highest ISR routine execution time: ndis.sys - NDIS 6.20 driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.048895
Driver with highest ISR total time: ataport.SYS - ATAPI Driver Extension, Microsoft Corporation
Total time spent in ISRs (%) 0.136389
ISR count (execution time <250 µs): 42393
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1531.650
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 342.01 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.417787
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.758382
DPC count (execution time <250 µs): 93506
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 0
DPC count (execution time 1000-1999 µs): 196
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: latmon.exe
Total number of hard pagefaults 88
Hard pagefault count of hardest hit process: 44
Number of processes hit: 4
PER CPU DATA
CPU 0 Interrupt cycle time (s): 3.108490
CPU 0 ISR highest execution time (µs): 120.60
CPU 0 ISR total execution time (s): 0.267319
CPU 0 ISR count: 42393
CPU 0 DPC highest execution time (µs): 1531.650
CPU 0 DPC total execution time (s): 1.446290
CPU 0 DPC count: 80378
CPU 1 Interrupt cycle time (s): 0.148506
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 23.30
CPU 1 DPC total execution time (s): 0.040122
CPU 1 DPC count: 13324
RAM:2GB,
GPU:Nvidia GT220,
MB5LD2-X/1333,
Windows 7 64-bit,
Things i've tried:
1.changed hdd,
1.updating BIOS,
CONCLUSION
SYSTEM INFORMATION
Computer name: X-PC
Processor groups: 1
RAM: 2047 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 1 ISR count: 0
