HIS 4830 : Help me About an issue regarding HIS 4830
Noctis
8
Hello Guys,
I have
1. Mother Board MSI (K9N NEO-V3).
2. Processor AMD Athelon 64 X2 4600+.
3. RAM Corssair XMS-2 (1GB) 800 MHZ.
4. Hard Disk 40 GB IDE.
5. DVD ROM.
6. Graphics card HIS HD 4830 (Fan). 512 MB (256 Bits).
7. PSU Asus Vento 350W/400W(Peak)
8. OS: Windows XP-32 Bit (Service Pack 2)
9. Drivers: Catalyst 9.6
ISSUE:
After installing Catalyst CC 9.6, It is hanged when it shows the Windows XP boot screen.
PLz reply and help me.
BUT BRO THE PSU CALCULATOR AND GURU3D SAYS THAT 350 OR 400 WATT PSU SHOULD WORK.
WHAT SHOULD BE IT ?
i ran a 4830 off a 350 watt psu and the volts were way low so.......i upgraded you may need to do the same .... one more thing are you running stock clocks?
thanks dude.
and whats a "stock dock"?
THANKS ALOT .
PROBLEMO SOLVED.
I SIMPLY UPGARADED THE PSU.
THNX ALOT GUYS.
I REALLLY APPRECIATE UR HLP
THANKS ALOT .
PROBLEMO SOLVED.
THNX ALOT GUYS.
