His h785f2g2m radeon hd 7850 2gb dual monitor question
killercripple
12
Im being offered the HIS 7850 2gb as a at cost upgrade, from the company that built my computer. To replace my 6850 that died 6 weeks ago.
My question ism can i dual monitor with this card and if yes how would i go about setting it up?
I want Extended mode (gaming on one, w/e on the other)
My old card had dual dvi ports and this one doesn't.
http://www.hisdigital.com/un/product2-698.shtml
could i get a hdmi to dvi cable? that way i can run both monitors at 1920x1080?
Exactly you would set it up the same exact way you would with the other card you had connecting your monitors to the card with whatever adapter/s your card supports and placing your monitors into extended desktop.
Yes, I think something like this would work:
http://www.globalindustrial.com/p/electrical/A-V-data-networking/Audio-Video-Components/hdmi-to-dvi-cable-standard-series-3-ft?utm_source=google_pr&utm_medium=cpc&utm_campaign=AudioVideo-Components-google_pr&infoParam.campaignId=T9F&gclid=CNb42OjE3LQCFQsGnQodUnEAcg
But the simple adapter I linked to should work just fine reusing your current dvi cable.
I see no problem with using a vga connection at 1080P either.
