I have a windows 10 PC that has p8p67 asus deluxe mother board and it has corsair vengeance DDR3 2133mhz 4x8gb total 32GB memory sticks and i7 2600k cpu, no overclock, everything is default.
The problem is sometimes when I touch in the computer, such as opening the cover and changing SSD cables or removing hardware etc causes an issue; When I start the computer, nothing comes to screen and no signal to keyboard or no startup beep sound, then after 3-5 seconds it turns off completely and then starts back automatically and stays like that, no screen, no beep. If I remove all memory sticks the board sounds memory alert beep.
Then I remove my memory sticks and hit them on the wall few times then put them back in mixed order after doing this 2-3 times the issue gets fixed and the computer works without any problem until I open the cover and change something in the future. I am sure it will work fine 6 months or more if I dont touch it. Because this issue has happened in the past 2 times and I did the same thing then the computer worked at least 6 months without any issue until I touch it inside.
Do I have a bad/unstable ram or is this a static electric issue from my hands ? I tried to remove the battery and power cable and wait 4-5 minutes, didnt help. The only solution was to removing memory sticks and hit them on the wall.
Thanks for help.
Thanks for help.
