G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I must be doing something wrong. It seems that I can setup the
quality, size and orientation of a print in the dialog box, but it does
not stay (even if I select "save settings"). I endured it with my
Epson 740, but now with a Canon MP750 and its front panel controls, you
would think that the quality, size and source that you set would be
what is used when you print from an application. The only thing that
seems to default from the front panel settings is the source of the
paper. Everything else seems to stay letter size, portrait and plain
paper. Even if the front panel says 4 X 6, photo. I don't know where
you determine the normal landscape on the MP750 front panel (do you put
the 4 X 6 paper in landscape?)
Is there a way to keep the settings you set in the printer dialog box?
Is there a way to have the settings you make on the printer panel be
used by the printer driver?
Many thanks to anyone that helps me here.
Eric
Eric
