Thanks for reading. This is most likely for an experienced Network professional, since the equipment is relatively proprietary.
This question involves a baffling issue with a new (used equipment factory reset) Pakedge home Ethernet and wireless WAP network. My experience it novice at best. The system was installed by an a/v integrator with average network experience (so, you get the picture?) The system is designed to run a home A/V system as well as provide Wireless internet access.
The network is atrocious, spotty, sluggish, both Ethernet and wireless.
Setup is:
Provider: Comcast Xfinity Gigabit
Modem: Netgear CM1105V
Router: Pakedge RK-1
Main Switch: Pakedge S24P8
PoE+ Switch: Pakedge SX-8P
Wireless Controller: Pakedge NK-1
WAPS: (4) Pakedge WX-1
SSID's - 2 (2.4 & 5 Separate)
Band Steering Enabled
A single VLAN
Router: DHCP with WAPS Reserved
Controller and PoE Switch Static (but withing the RK-1's DHCP Range)
Major devices Reserved
Flatish setup
Modem>Router
Router to Main Switch
Controller and PoE+ Switch connected to main switch with all ethernet devices
WAP's connected to PoE+ switch
Feels like a loop or something is bombarding. Sonos is also on the system both ethernet and wireless. I mention that because a lot of people are suspect of Sonos and flooding.
Wireless signal is somewhere between 200-300 almost every inch of the house.
Ethernet devices seem very sluggish.
Wireless is unusable most of the time (but for some reason a Nest Hello wireless door bell seems to work).
From iPhones seems to go to google okay. Once you click a site, it gets sluggish if at all.
The WAPs have current firmware, as does the router. The PoE+ Switch needs an update, but it requires a dealer. Same with NK-1 Wireless Controller.
I have never connected to all of the WAP's through the controller. But can reach them via ip.
Please help me figure this out?
Thank you!
Setup is:
A single VLAN
Flatish setup
Modem>Router
Thank you!
