Hey all!
Just wanted to throw this out there to those who know a lot more about this stuff than I do. I've done a fair amount of builds over the years, and built myself a new one about 6 months ago and have been adding to it here and there since. It works great, but as compared to high end machines I get mixed results when I run benchmarks. So thought I'd see what input the community can give me on my build.
Case:
Rosewill Gaming Computer Case - ATX Mid Tower - Top HDD Dock, Side Window Panel, 5 Preinstalled Fans - BLACKHAWK
MB:
ASRock X470 Master SLI/AC AM4 AMD Promontory X470 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
CPU:
AMD RYZEN 5 2600 6-Core 3.4 GHz (3.9 GHz Max Boost) Socket AM4 65W YD2600BBAFBOX Desktop Processor
RAM:
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C16D-16GVGB
GPU: (this one I plan on hopefully upgrading here in the next 6 months, but works well for what it is)
XFX RS Black RX 570 OC+ 4GB DDR5 3xDP HDMI DVI w/Custom Backplate
M2's:
1x XPG SX8200 PCIe NVMe Gen3x4 M.2 2280 240GB SSD (ASX8200NP-240GT-C) w/ Black XPG Heatsink (In M2 PCIe Gen3x4 slot)
1x WD Black 256GB Performance SSD - M.2 2280 PCIe NVMe Solid State Drive - WDS256G1X0C (In M2 PCIe Gen2x2 slot)
HDD:
2x WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM (in RAID 1)
Optical Drives:
1x LG BD Burner
1x LG DVD Supermulti Burner
Card Reader:
1x Rosewill card reader
Power Supply:
Rosewill Glacier Series 600W Modular Gaming Power Supply with Silent Aero-Diversion Fan, 80 PLUS Bronze Certified, Single +12V Rail, Intel 4th Gen CPU Ready, SLI & Crossfire Ready - Glacier-600M
Speakers:
Rosewill BA-001 2.1 Multimedia speaker system
Monitors:
1x LG 27UD58P-B 27" IPS 4K UHD Free-Sync Gaming Monitor, 3840 x 2160, 5ms Response Time, 1000:1 Contrast Ratio, DisplayPort, HDMI, Tilt / Height Adjustable, VESA Compatible
1x Acer KG1 Series KG221Q bmix Black 21.5" TN 1ms (GTG) 75Hz, LCD/LED Gaming Monitor, Widescreen FHD 1920x1080, AMD FreeSync Technology, Acer Flicker-less Technology, BlueLightShield Technology, VESA Mountable, 2 x 2 W Built-in Speakers
OS:
Windows 10 Pro
System works great but I'm always looking for feedback/suggestions on components or configurations I could use to make it better. Primarily used for digital video and photo editing, but I do have my guilty pleasure games I play occasionally.
Thanks in advance for any feedback!
Case:
MB:
CPU:
RAM:
M2's:
HDD:
Optical Drives:
1x LG BD Burner
Card Reader:
Power Supply:
Speakers:
Monitors:
OS:
Windows 10 Pro
