Home build upgrade advice please
Shub
8
Hi all :hello:
I need advice on upgrading my home build me and a friend built 2 years ago. Unfortunatly my friend who advised and helped me on the build died last year, so im lost for advice on an upgrade and could really use some pointers.
I have a NVidia 8800 ultra which im happy with but need advice on a new CPU (intel), Motherboard, RAM, fans, sound card and an extra 500gb hard drive which will be compatible with my 8800 ultra and would preferably fit into my Antec P182 Super Midi Tower Case, although i can change case if need be.
Primarily a gaming PC.
My budget limmit is £600 - $873.
Theres such a wide range of components on sale i have no clue whats best or compatible.
Any advice sugestions would be very much appreciated!
Thanks, Shub.
belial2k
1,043
No need for a sound card with a quality MB... there are several great 500gb hard drives in the $60 range, but I prefer WD caviar black. I would also add a Coolit Domino liquid cooling to the system below for about $100...this will allow you to do some serious overclocking. I chose a less expensive MB, but you could upgrade to one in the $300 range and still stay in budget.
Qty. Image Product Description Unit Price Savings Total Price .
Update13-130-221
MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard
MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Model #:X58 Pro
Item #:N82E16813130221
Return Policy:Limited Non-Refundable 30-Day Return Policy
In Stock
Mail in Rebate
Note (Add13-130-221)
Save Cancel
$199.99 $199.99
Update19-115-202
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
Model #:BX80601920
Item #:N82E16819115202
Return Policy:processors (CPUs) Return Policy
In Stock
Note (Add19-115-202)
Save Cancel
$279.99 $279.99
Update20-231-247
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL8TU-6GBPI
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL8TU-6GBPI - Retail
Model #:F3-12800CL8TU-6GBPI
Item #:N82E16820231247
In Stock
Note (Add20-231-247)
Save Cancel
$99.99 -$10.00 Instant $89.99
Subtotal: $569.97
Sorry about your friend :(
With the P182 and 8800Ultra you are limited to 4 hard drives, I believe.
The WD6401AALS (WD Caviar Black 640GB) is the most popular hard drive these days AFAIK, and it deserves it.
I agree with all your points above, except the liquid cooling system/overclocking. He said "i have no clue whats best or compatible", and I think attempting to overclock would be dangerous for him. Without overclocking, the stock cooler will be just fine.
Now, if you're REALLY nice, give him some links to www.overclockers.co.uk or www.scan.co.uk. His budget is in British pounds, and Newegg doesn't ship to the UK.
I missed the part about fans. You don't need to buy extra fans just because you're replacing some Core 2/P45/DDR2 setup (or whatever you have now) with an i7/x58/ddr3 setup. The P182 can handle all that just fine.
belial2k
1,043
Sorry Shub, you know us arrogant americans...I would imagine you will have no problem finding the same items from your UK discounters well under your budget. And aevm is correct, that if you are running stock speeds the stock cooling will be fine, and that will save you even more.
Shub
8
Many thanks guys, you have been a great help.
No worries about the pound to dollar change, advice on quality compatible parts was all i needed.
Thanks very much, Shub ;)
Shub
8
good thing overclockers has a X58 board for £125 ex vat, should be about £155 inc, saves you about £15 already.
Great thanks.
Oh... the only thing i forgot to ask was what wattage power supply would i require to easily run this system?
Something like Corsair 650W should be plenty.
If you're planning to add a second video card, I'd recommend the Corsair 750W.
Edit: why the Corsair 650W and not some other 650W PSU:
1. because you need extra long cables for the P182, and the Corsair has them; other models may not have them
2. because there are plenty of models claiming 650W but not many can deliver 52A, like the Corsair.
