Hey guys,
This is my first time building a PC from scratch, so if I am being an idiot here, just tell me. Regardless, I started building my PC last night. All of the hardware fit in fine, but when I went to boot the PC for the first time, everything turned on (graphics card fan, cpu fan, chassis fan, lights, ect..) but it did not give me any video signal no matter how many different monitors I tried with it. Eventually, I started getting a red memory access light on my motherboard and I looked online for a while and found that the motherboard I am using, M4A89GTD USB/PRO, would not boot with two sticks of RAM sometimes upon entering BIOS. I took out a stick of RAM but it still didn't work and the memory access light blinked a few times then stopped. I decided to take a shot in the dark and unplug the GPU (I had connected a PCIE 6+2 PIN with just the 6 pin connected and another regular 6 PIN connected too. After I unplugged it, I got it to boot and I installed Windows 7 64 bit. After that, I installed the motherboard drivers and all updates needed. I then turned off the pc, plugged in the GPU, and put in the other stick of RAM and it did the same thing as before. Can anyone find out what I am doing wrong???
System Specs:
AMD 1100 3.3Ghz CPU
Nvidia GTX 560 ti Palit 2gb
Lite-On scribe multiformat dvd writer
Hitatchi 2tb 7200 RPM 64mb cache HDD
8gb (2x4) Gskill DDR3 1333mhz RAM
Windows 7 Home Premium 64 bit
Earthwatts 650 watt PSU
XION Predator gaming case
System Specs:
AMD 1100 3.3Ghz CPU
