Home Lab build
xInfluX
68
Looking to build a test/study lab for various VMs, servers, practice with Microsoft server 12 and 16, hyper v and practicing powershell scripts on. Just something I want to keep in the house to learn on. Dont want to spend a ton of money. I'd like it to be as cheap as possible and I'm okay with ebay parts. Thanks
Yes.
Focus on as much memory as you can, so at lease 32GB and as many cores as you can.
Compare a new AMD 2600 in terms of what you can get from eBay. The price differential will not be that great.
Also consider using esxi as a bare metal hypervisor rather than Hyper-V. (You can always run win16 Hyper-V as a VM anyway).
Look for sellers that have a returns policy for DOA items.
At minimum, go with 16GB of RAM if you only planning on running two concurrent VMs with 4GB of RAM allocated to each of them. The more RAM, the better; so definitely look toward 32GB if you can.
You'll want at least a four core CPU, two network ports, and ideally an SSD. Again, depends on how many VM and of what content, but a 256GB to 512GB SSD should suffice. You'll be creating dynamic VHDs, so it should be plenty of space.
So minimum quad core CPU, as much ram as possible. An ssd for the OS and VM stuff. A couple of tb hdd and that should do? What kind of mobo and power supply should I be looking for?
