My network is set up in the following manner:
Cable modem goes into Netgear wired/wireless router
3 computers use wireless connections for networking and internet. All is well.
The Vonage modem (with built in router) connects into one of the ethernet cables in the Netgear router.
A 4th computer connects to the Vonage box.
Internet connections work on everything, and Vonage works fine. However, the computer connected through the Vonage box cannot see any of the other computers on the network and file and print sharing no longer works.
This is because the Vonage box is on a different Subnet as the main router. The main router uses 192.168.1.XXX while the Vonage box uses 192.168.15.XXX.
I tried some stuff that I've read to no avail. I tried turning off DHCP on the Vonage box while manually setting its IP address to be 192.168.1.150, but this doesn't work and the 4th computer still uses 192.168.15.1 as the gateway. I can ping 192.168.1.150, which it connects to, but I still have to use 192.168.15.1 in the browser to change the Vonage Box settings.
So, I thought, I'd try the reverse. I set the Netgear router DHCP to control 192.168.15.XXX, but when I do this the Vonage box sets itself to 192.168.16.1...
The modems and routers have to be set up this way because of the way the lines are ran, where the fax machine and phones are, etc... I would like to continue using the wired connection on the 4th computer rather than the wireless as well...
Any thoughts on what else I can try? The info from Vonage isn't helpful at all with this and doesn't address any of the home networking stuff...
Thanks.
Thanks.
