Hi, so about 4 months ago I built my first custom PC. It worked beautifully until recently when it just refused to power on. the power button causes the PC to light up and case fans to power on, but the computer will not POST no matter what I do. The CPU fans do not come on.
As of writing this, I have tried reseating the CPU, putting the GPU in other PCI Express slots and removing it entirely. I have tried removing the RAM and trying the one or two 8gb sticks in various configurations in the 4 available slots. I have removed all plugs and connectors and re-inserting them. The case has a small fan speed controller. I have tried connecting the two CPU fans directly to the Mobo. None of this has changed anything.
Next I took the machine to Best Buy and paid to have them to swap parts in to see if they could get the machine to at out POST. They didn't have a Mobo with an LGA 1151 socket to test so they determined that, confirming my fear, the motherboard was bad. I send that to the manufacturer (ASUS) with an RMA request. After receiving the board back, I still have the same issue. I should have taken a picture of the serial number on my original board, because I'm not sure what I got back was different, but it didn't appear that it was as pristine as my original one, so I'm assuming they did as they claimed and sent new a new (to-me) motherboard.
Now I've asked other shops by phone at this point what they could do to test the problem so I can fix this and all have claimed that they would do the same process and don't have high end components lying around to test everything.
The specs are as follows:
Windows 10 Home Pro OS
Fractal Define R6
Intel i7 8700k (overclocked to 4.0 GHz)
Asus Maximus Code X
Nvidia RTX2080
Samsung 860 1tb SSD
Corsair HX750 (750 WATT Platinum) PSU
2x 8gb Corsair vengeance ddr4-3200 mhz RAM
Noctua NH-D15
Can someone please recommend what I can do here besides my backup plan to replace everything since it's all under warranty?
As a side note, fuck the the front panel connector and screw tempered glass. Thanks for listening.
Fractal Define R6
Asus Maximus Code X
Nvidia RTX2080
Samsung 860 1tb SSD
Noctua NH-D15
