I have a desktop PC with no wireless adapter. I built it myself and it's around 3 months old now. I use a homeplug system to access the internet that has been working fine for the most part. Occassionally late at night (Gone 1am) the Internet would cut out, but a troubleshoot by windows that reset the local area network adapter has never failed to fix the problem.
This happened last night at around the same time, and since then the homeplug system has not functioned correctly. It was working absolutely perfectly up to that point and nothing changed. I am writing this from a friends laptop having confirmed that he is having the same problem. When I connect directly to the router via an ethernet I have no issues and all other devices are able to connect to the Wireless network flawlessly. I noticed he had a series of tunnel adapters, but I only have one on my PC, so I presume that is not the problem.
On the homeplugs themselves, the middle lights are not on, I believe the other the two activated lights refer to the Power and the Ethernet cable. The light where the ethernet links to the router is on. I first installed these years ago and have completely forgotten what the lights refer to and which ones need to be on or not. I am using TP Link AV500 homeplugs if that makes any difference, both of which are plugged into the wall directly and always have been.
To me they should all be on, and this is almost certainly the problem, but I have no idea how to fix it
Here is the /ipconfig all:
C:\Users\Student>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : N260571012-4C
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Peer-Peer
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : Realtek RTL8188CE Wireless LAN 802.11n PC
I-E NIC
Physical Address. . . . . . . . . : 1C-65-9D-52-9C-85
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 88-AE-1D-EF-24-C4
Link-local IPv6 Address . . . . . : fe80::9965:ab2e:8237:8bb4%10(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.139.180(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 243838493
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-41-64-69-88-AE-1D-EF-24-C4
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #6
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 20:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #12
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #3
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #4
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #5
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #7
Tunnel adapter Local Area Connection* 16:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #8
Tunnel adapter Local Area Connection* 21:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #13
Tunnel adapter Local Area Connection* 23:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #15
Tunnel adapter Local Area Connection* 22:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #14
Tunnel adapter isatap.sm.esol.dur.ac.uk:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 24:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #16
Tunnel adapter Local Area Connection* 26:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #18
Tunnel adapter Local Area Connection* 27:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #19
Tunnel adapter Local Area Connection* 28:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #20
Tunnel adapter Local Area Connection* 29:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #21
Tunnel adapter Local Area Connection* 32:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #24
Tunnel adapter Local Area Connection* 34:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #26
Tunnel adapter Local Area Connection* 36:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #28
Tunnel adapter Local Area Connection* 46:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #29
Tunnel adapter isatap.{199BF4D5-36E5-4A37-A56A-5B635A73AA40}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Local Area Connection* 67:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
C:\Users\Student>
I-E NIC
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
C:\Users\Student>
