Hooking up Cable for TV when using High Speed Cable
David
2,039
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
This is probably a stupid question-I have a high speed cable connection
going to my computer. If I buy a TV capture card, do I just use a splitter
on the incoming high speed data line to receive my TV signal or will I have
to use another cable line for a TV signal?
dg
"David" <gorenstein@msn.com> wrote in message
news:4eppc.52573$536.9026576@attbi_s03...
splitter
have
It depends how the cable company handles the internet signal. While most
have the internet signal on the same line as the TV channels, some have
seperate lines for each. AFAIK, some companies can also enable/disable
channels on lines and such.
If both the TV signal and the signal responsible for data transfer are
enabled on same line, you could probably use a simple splitter to get both.
However, this will decrease signal quality a bit, which isn't that big a
deal unless the signal is weak to begin with.
I hope this helps,
Glzmo
Thanks-sounds like I should be able to go the splitter route which is an
easy solution.
dg
"Glzmo" <glzmo@NOyahooSPAM.com> wrote in message
news:stppc.98976$O9.91183@news.chello.at...
> splitter
> have
both.
> I hope this helps,
> Glzmo
news:NLppc.53573$z06.7575318@attbi_s01...
> easy solution.
> dg
I have Comcast here in Seattle WA. With Comcast you must have at lest a
basic cable TV subscription for a splitter to work. It used to work when it
was still AT&T but soon after Comcast took over, no more free TV. JLC
I am in WA as well and have basic service, so I guess it will be fine-that
is good news.
dg
"JLC" <j.jc@nospam.com> wrote in message
news:Rcqpc.5707$gr.408933@attbi_s52...
> > easy solution.
> > dg
it
I have done exactly this. I had a splitter for the line going to 2 TV's.
When I got cable internet, they split the line again, and ran a line to the
computer. I then split that line to both the cable modem and my ATI all In
wonder tuner. No signal loss or picture quality problems. Apparently, I
must have a very good signal.
> easy solution.
> dg
connection
> > splitter
> > have
> both.
> > I hope this helps,
> > Glzmo
On Sat, 15 May 2004 18:27:14 -0400, "Guess Who"
Yea, you must. I had a four way splitter and when the Internet tech
guy saw that he gave me a high quality two way splitter to use for my
cable tv and internet connection, I only needed two way and he said
four way splitters are not good when you need one for the internet.
>dg
Put a splitter on the Cable coming from the wall outlet. One goes to Video
Card, other goes to cable modem.
If you have cable TV service, it should work. But remember this...adding a
splitter to the line will likely change the signal level your cablemodem
gets. This could cause your modem to go offline. I work for a cable
company's internet help desk, so I've seen it happen MANY times. Sometimes
it's just a matter of luck. If the internet connection doesn't work after
adding a splitter, call the cable company and they can setup a splitter that
will allow both the modem and tuner card to work fine for ya...again, seen
it MANY times...so, yeah...
Cliffz0rz
splitter
have
> dg
In article <WY7qc.15961$325.518873@news20.bellglobal.com>, "Cliffz0rz" <cliffz0rz@hotmail.antispam> wrote:
> Cliffz0rz
So the cable co has "Magic" splitters??? bwahahahaa
Bet they charge you for them!
>splitter
>have
>> dg
>> Cliffz0rz
Cable COs tend to use "bidirectional" splitters.
Unless you specifically look for the bi type. the offtheshelf splitter
you get will be one way..
which most likely will work, but the cable co doesn't get diagnostic
info back to thier system and may see it as the box being offline and
do weird things :)
-T-
>>splitter
>>have
>>> dg
