Hooking up HDMI and DVI to the same monitor from separate sources
Cymerian
40
I have a Samsung S27A950D. I want to connect two computers to it. One DVI and one HDMI. If I do this, will I be able to switch between the sources at will?
This will work fine.
You should be able to switch sources by pressing a button (it's next to auto adjust on my friends Samsung monitor) looking at your monitors manual it is the button with the square with an arrow pointing into it (in the middle of the directional buttons)
Thanks. Worked exactly as you said.
